Router reboot automatically
talat2good
Hi Guys
Today my Cisco router reboots automatically .I searched allot but did not found any reason.Following is the msg in sh version.When the router reboot no one was login to the router.
System returned to ROM by abort at PC 0xBFC01ED0
My config register value is 0x2102 so no change of break sequence of causing reboot.Any clue ?
6 Replies 6
paolo bevilacqua
typically, is a software crash. With patience, one could get to a specific reason or bug, however it is recommended that you upgrade to the latest maintenance releaseof the version you are running. Chances are it won't happen anymore.
Many thanks for your reply
My current IOS is c7200-adventerprisek9-mz.124-2.T5.bin
on 7206 VXR (NPE 400).Now which IOS do you recommend for upgrade
Regard
Talat
Actually you are already running the latest version of 12.4(2)T. At this point, to eliminate blind upgrades, either you go to the TAC to find what caused the crash, or do yourself using 'output interpreter'.
Since both things require a support contract, If you can't do the above, post here output of show stacks | begin Crashinfo
It does not show any thing
sh stacks | begin Crashinfo
sh stacks | begin ?
LINE Regular Expression
sh stacks | begin crashinfo
Then try show stacks alone.
At the moment is have changed the IOS of the router to c7200-jk9s-mz.123-21.bin.It was rebooting very frequently.So far since last 2 days its under observation and working normally.Let see
Thanks for all the help
Regard
Talat
