Router reboot reason
Fakrul Alam
Hi All,
Bellow is the show version command of CISCO ASR 1000F route:
ROM: System Bootstrap, Version 12.2(17r)SX5, RELEASE SOFTWARE (fc1)
HOSTNAME uptime is 1 hour, 5 minutes
Uptime for this control processor is 1 hour, 4 minutes
Time since HOSTNAME switched to active is 1 hour, 4 minutes
System returned to ROM by  power cycle at 19:06:57 BDT Sun Dec 26 2010 (SP by power on)
System restarted at 19:28:07 BDT Sun Jun 19 2011
System image file is "sup-bootdisk:s72033-ipbase-vz.122-33.SXI2a.bin"
Last reload reason: Reload Command
cisco WS-C6509-E (R7000) processor (revision 1.5) with 1040384K/8192K bytes of memory.
Processor board ID SMC134900GW
SR71000 CPU at 600Mhz, Implementation 1284, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
116 Virtual Ethernet interfaces
99 Gigabit Ethernet interfaces
10 Ten Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Patching is not available since the system is not running from an installed image.
To install, please use the "install file" command.
From the output it seems that the router has been reloaded due to reload command. I have tried to compare with other Cisco 3900 series router and Cisco 4500 series switch. None of the show the output as same way. So does the router rebooted due to relaod command or power cycle? Beside this what does it mean by "patching is not available" at the bottom of the output.
Fakrul
7 Replies 7
gephelps
Why do you believe this is an ASR1000?
If you look at the reported date of the power cycle it is from last year, so I would ignore that. Instead the reload command would seem more likely. What does the output of the command remote command switch show nvlog look like?
You are running Modular IOS. In earlier versions there was the option to install it, but I believe that was removed in 12.2(33)SXI3 so I would ignore that output.
Fakrul Alam
Sorry, I missed out. It's Cisco 6509 switch.
Bellow is the output of "remote command switch show nvlog"
01. 01/22/2010 02:01:45: pf_redun_negotiate:Initialized as ACTIVE processor
02. 01/21/2010 18:11:32: oir_reload_chassis:Reload Chassis requested
03. 01/22/2010 02:13:33: pf_redun_negotiate:Initialized as ACTIVE processor
04. 01/22/2010 02:17:27: pf_redun_negotiate:Initialized as ACTIVE processor
05. 01/22/2010 02:27:18: pf_redun_negotiate:Initialized as ACTIVE processor
06. 01/22/2010 02:45:10: oir_reload_chassis:Reload Chassis requested
07. 11/04/2010 11:24:12: pf_redun_negotiate:Initialized as ACTIVE processor
08. 11/04/2010 11:44:27: pf_redun_negotiate:Initialized as ACTIVE processor
09. 12/25/2010 11:47:26: pf_redun_negotiate:Initialized as ACTIVE processor
10. 12/26/2010 11:14:46: pf_redun_negotiate:Initialized as ACTIVE processor
11. 12/26/2010 19:06:55: oir_reload_chassis:Reload Chassis requested
12. 12/26/2010 13:09:40: pf_redun_negotiate:Initialized as ACTIVE processor
13. 05/26/2011 23:42:13: pf_redun_negotiate:Initialized as ACTIVE processor
14. 06/19/2011 13:28:12: pf_redun_negotiate:Initialized as ACTIVE processor
Does this switch have dual supervisors? If so please get the output of the nvlog for the standby supervisor.
From the nvlog output it looks like the supervisor was reset due to external forces since the last two logs are initialized as active. If the switch was rebooted by the cli or crahsed I would expect to see a corresponding entry in this log.
Thanks for your quick response.
No there is only one superviros. I have checked the module. It show the following output:
HOSTNAME#show module
Mod Ports Card Type                                                       Model
  1   48  CEF720 48 port 10/100/1000mb Ethernet       WS-X6748-GE-TX
  2   48  CEF720 48 port 10/100/1000mb Ethernet       WS-X6748-GE-TX
  3    8  CEF720 8 port 10GE with DFC                      WS-X6708-10GE
  5    5  Supervisor Engine 720 10GE (Active)              VS-S720-10G
If this is the case, that what is does the "Last reload reason: Reload Command" means?
Fakrul,
Did you ever find out what was the issues.
I have a 6500 that reloads every two weeks based on the nvlog and got the same output on the show ver.
Post your output to the command "sh version".
HOSTNAME#sh version
Cisco IOS Software, s72033_rp Software (s72033_rp-ADVENTERPRISEK9_WAN-M), Version 12.2(33)SXJ1, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Wed 22-Jun-11 18:03 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)S4, RELEASE SOFTWARE (fc1)
HOSTNAME uptime is 2 days, 3 hours, 18 minutes
Uptime for this control processor is 2 days, 3 hours, 18 minutes
Time since HOSTNAME switched to active is 2 days, 3 hours, 17 minutes
System returned to ROM by  power cycle at 18:26:09 CST Tue Aug 16 2011 (SP by power on)
System restarted at 20:01:06 CST Sun Dec 8 2013
System image file is "disk0:s72033-adventerprisek9_wan-mz.122-33.SXJ1.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6513 (R7000) processor (revision 1.0) with 458720K/65536K bytes of memory.
Processor board ID SAL09018PPM
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
1 SIP-200 controller (8 Channelized T3).
71 Virtual Ethernet interfaces
4 FastEthernet interfaces
85 Gigabit Ethernet interfaces
16 Ten Gigabit Ethernet interfaces
224 Serial interfaces
8 Channelized T3 ports
8192K bytes of packet buffer memory.
HOSTNAME#remote command switch show nvlog
NVRAM log:
01. 06/01/2012 10:12:59: pf_redun_negotiate:Initialized as ACTIVE processor
02. 11/26/2012 01:59:11: pf_redun_negotiate:Initialized as ACTIVE processor
03. 12/10/2012 01:56:36: pf_redun_negotiate:Initialized as ACTIVE processor
04. 12/24/2012 01:56:28: pf_redun_negotiate:Initialized as ACTIVE processor
05. 01/07/2013 01:56:34: pf_redun_negotiate:Initialized as ACTIVE processor
06. 01/12/2013 15:03:27: pf_redun_negotiate:Initialized as ACTIVE processor
07. 01/21/2013 01:56:41: pf_redun_negotiate:Initialized as ACTIVE processor
08. 02/04/2013 01:56:54: pf_redun_negotiate:Initialized as ACTIVE processor
09. 02/18/2013 01:57:02: pf_redun_negotiate:Initialized as ACTIVE processor
10. 03/04/2013 01:57:10: pf_redun_negotiate:Initialized as ACTIVE processor
11. 03/18/2013 01:57:20: pf_redun_negotiate:Initialized as ACTIVE processor
12. 04/01/2013 01:57:27: pf_redun_negotiate:Initialized as ACTIVE processor
13. 04/15/2013 01:57:33: pf_redun_negotiate:Initialized as ACTIVE processor
14. 04/29/2013 01:57:43: pf_redun_negotiate:Initialized as ACTIVE processor
15. 05/13/2013 01:57:50: pf_redun_negotiate:Initialized as ACTIVE processor
16. 05/27/2013 01:58:01: pf_redun_negotiate:Initialized as ACTIVE processor
17. 06/10/2013 01:58:14: pf_redun_negotiate:Initialized as ACTIVE processor
18. 06/24/2013 01:58:19: pf_redun_negotiate:Initialized as ACTIVE processor
19. 07/08/2013 01:58:29: pf_redun_negotiate:Initialized as ACTIVE processor
20. 07/22/2013 01:58:35: pf_redun_negotiate:Initialized as ACTIVE processor
21. 08/05/2013 01:58:42: pf_redun_negotiate:Initialized as ACTIVE processor
22. 08/19/2013 01:58:52: pf_redun_negotiate:Initialized as ACTIVE processor
23. 09/02/2013 01:59:03: pf_redun_negotiate:Initialized as ACTIVE processor
24. 09/16/2013 01:59:16: pf_redun_negotiate:Initialized as ACTIVE processor
25. 09/30/2013 01:59:23: pf_redun_negotiate:Initialized as ACTIVE processor
26. 10/14/2013 01:59:31: pf_redun_negotiate:Initialized as ACTIVE processor
27. 10/28/2013 01:59:40: pf_redun_negotiate:Initialized as ACTIVE processor
28. 11/11/2013 01:59:51: pf_redun_negotiate:Initialized as ACTIVE processor
29. 11/25/2013 01:59:58: pf_redun_negotiate:Initialized as ACTIVE processor
30. 12/09/2013 02:00:11: pf_redun_negotiate:Initialized as ACTIVE processor
The switch does not have a dual sup. The system reloads and does not provide a crashinfo fiile if it does crash.
Im wondering if it is tied to CSCtb27643 or if there are any known issues with silent reloads on the currernt code i am running.
