Router Reload
darora_83
Hi ,
I have a 7200 router which reloaded couple of times last month and it always shows that router reloaded due to power-on. There was no power issue on site . Wanted to know could this be any bug.
IOS (tm) 7200 Software (C7200-JK2S-M), Version 12.1(19)E2, EARLY DEPLOYMENT RELEASE
SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tacCopyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Wed 30-Jul-03 04:53 by hqluong
Image text-base: 0x60008C08, data-base: 0x617FE000
ROM: System Bootstrap, Version 12.2(1r) [dchih 1r], RELEASE SOFTWARE (fc1)
BOOTLDR: 7200 Software (C7200-BOOT-M), Version 12.0(13)S, EARLY DEPLOYMENT RELEASE
SOFTWARE (fc1)
IIRT02 uptime is 1 hour, 13 minutes
System restarted at 07:50:12 UTC Sat Sep 28 2013
System image file is "sup-slot0:/c7200-jk2s-mz.121-19.E2.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco 7206VXR (NPE300) processor (revision D) with 229376K/65536K bytes of memory.
Processor board ID 21304865
R7000 CPU at 262Mhz, Implementation 39, Rev 2.1, 256KB L2, 2048KB L3 Cache
6 slot VXR midplane, Version 2.1
Last reset from power-on
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
Primary Rate ISDN software, Version 1.1.
PCI bus mb0_mb1 has 1000 bandwidth points
PCI bus mb2 has 580 bandwidth points
WARNING: PCI bus mb0_mb1 Exceeds 600 bandwidth points
5 FastEthernet/IEEE 802.3 interface(s)
31 Serial network interface(s)
2 Channelized T3 port(s)
125K bytes of non-volatile configuration memory.
46976K bytes of ATA PCMCIA card at slot 0 (Sector size 512 bytes).
4096K bytes of Flash internal SIMM (Sector size 256K).
Configuration register is 0x102
Deepak
sathvik k v
Level 3
Level 3
Hi Deepak,
Had faced a similar kind of issue with  Cisco 7206VXR (NPE-G1) few days back. Where the local engineer said there was no problem with power as there are other devices coneected to the same power supply. While surfing i remember reading a document stating this is a known issue with IOS release 12.2 when certain modules are installed.
Check if any new module was installed,IOS upgraded/downgraded and compatibilty of the modules on the device with the existing IOS.
Would suggest for a IOS upgrade.
Regrads,
Sathvik
