Router Selection
beem343434
What would be the best router/modules to select for a HQ router that would support 75+ Remote offices via a VPN Tunneling Protocal? Also what 800 series router would work best for the remote sites with quest DSL connection?
Edison Ortiz
At the HQ, I recommend going with the 2800 ISR
http://www.cisco.com/en/US/products/ps5854/index.html
The 1800 ISR, per spec, maxes out at 50 tunnels.
At the remote sites, the 850 Series should do the job http://www.cisco.com/en/US/products/hw/routers/ps380/index.html
HTH,
__
Edison.
Footnote:
"The Cisco IPsec and SSL VPN AIM supports up to 800 tunnels on the Cisco 1841"
