router simulator
revilo3246
does anyone knows of a good router/switch simulation which i can use to practice bgp and mpls, please let me know. thanks
Danilo Dy
Try DYNAGEN http://www.dynagen.org/ all you need is access to IOS.
Dandy
royalblues
Level 10
Level 10
Friend
have a look at dynamips which i feel is the best when it comes to router simulators.
www.ipflow.utc.fr/index.php/Cisco_7200_Simulator
Read the tutorials for installation and for creating sample toplogies
HTH, rate if it does
Narayan
mohammedmahmoud
Level 11
Level 11
I add my voice to both Narayan and Danilo, dynamips/dynagen is the best simulator by far, as you can test all the real life cases without restrictions, but you'll need to have the appropriate IOSs and a strong machine to run many routers.
HTH,
Mohammed Mahmoud.
