Router stock in rommon mode and won't boot
dacobelltacham
Hello Team
i am unable to get my router out of rommon mode find below some outputs from the router
Initializing Hardware ...
Checking for PCIe device presence...done
System integrity status: 0x610
Rom image verified correctly
System Bootstrap, Version 16.7(5r), RELEASE SOFTWARE
Copyright (c) 1994-2019  by cisco Systems, Inc.
Current image running: Boot ROM0
Last reset cause: LocalSoft
ISR4431/K9 platform with 8388608 Kbytes of main memory
rommon 1 >
rommon 4 > dir bootflash:
0   0         drw-     .dbpersist
0   0         drw-     sysboot
0   2131      -rw-     isr4400-universalk9.16.09.05.SPA.bin
0   0         drw-     .installer
0   0         drw-     core
0   0         drw-     .prst_sync
0   0         drw-     .rollback_timer
0   0         drw-     gs_script
0   0         drw-     tracelogs
0   0         drw-     virtual-instance
0   0         drw-     vman_fdb
0   0         drw-     onep
0   30        -rw-     throughput_monitor_params
0   35        -rw-     pnp-tech-time
0   121912    -rw-     pnp-tech-discovery-summary
rommon 5 >
rommon 5 > boot bootflash:isr4400-universalk9.16.09.05.SPA.bin
Located isr4400-universalk9.16.09.05.SPA.bin
Unsupported package header version (1634562163)
Failed to boot file bootflash:isr4400-universalk9.16.09.05.SPA.bin
rommon 6 >
12 Replies 12
dacobelltacham
what can i do to resolve this pleasw
Leo Laohoo
The file is corrupt or not downloaded complete.  File size is only 2131.
what do you think i should do? try to boot up the router from a USB ? tried
that yesterday but router couldnot read my USB Key
Did you format it for FAT 32? I'm pretty sure that's what it needs to be.
edit: this might help also
Troubleshoot Cisco 4000 Series ISR Stuck in ROMMON - Cisco
Ok i will try this because i formatted the file as a FAT and not FAT32
--> tried that yesterday but router could not read my USB Key
Which USB key/model do you have ?
Find another USB thumb drive:  32 Gb, FAT32 FAT16
Make sure the firmware is not corrupt by checking/comparing the MD5 hash of the file.
ok thanks let me try this and feedback
I made a mistake.
Should be FAT16.
hello if i have a 4G or 16G flash should it be FAT16 or FAT32 ?
FAT16
ok i will try the FAT32 and FAT16 respectively
