Router stuck in rommon mode
Buha_ZZ
Hi folks..  I was trying to change my IOS software on Router c867VAE-K9 but I make mistake and install wrong IOS so I'm stuck here... how to solve this problem and to install correctly IOS... I previously deleted factory IOS
System Bootstrap, Version 15.1(4r)M2, RELEASE SOFTWARE (fc1)
Copyright (c) 2011 by cisco Systems, Inc.
C860VAE advanced k9 platform with 256 MB of main memory
Booting flash:/c860vae-ipbasek9-mz.154-3.M4.bin
boot: Launch entrypt: 0x80800000
Self decompressing the image : ########################################################################################################################################################################################################################################################################################################################################################### [OK]
Wrong IOS image on ADVANCED K9 Router
System reload in 5 seconds
[CTRL-C KEY]
monitor: command "boot" aborted due to user interrupt
rommon 1 > dir flash
File system is not ready to use.
Please reset before access file system
rommon 2 >
rommon 2 > tftpdnld
Please reset before executing this command
rommon 3 >
Use this: c860vae-advancesecurityk9-mz.153-3.M3.bin
Leo Laohoo
Can you post the complete output to the following ROMMON commands:
1.  dir flash:
2.  set
The router is booting an IOS with IP Base feature set.
Try downloading the firmware with "Advanced Security" feature set.
I download all version IOS for series 860 but I'm not sure which exactly version to install for this model...?
Booting flash:/c860vae-ipbasek9-mz.154-3.M4.bin [CTRL-C KEY]
rommon 1 > dir flash:
rommon 2 > set
PS1=rommon ! >
BOOT=
RTC_STAT=0
BSI=0
RANDOM_NUM=905784326
RET_2_RTS=12:46:14 UTC Fri Feb 28 2020
RET_2_RCALTS=1582893975
?=-1
I fixed, Thanks man :)
