Router suggestion
harikrishna1991
We are planned to upgrade our ILL bandwidth to around 600Mbps.
Whether Cisco ISR 4451 router support the above mentioned bandwidth.
Any other alternate models
5 Replies 5
e.ciollaro
Level 4
Level 4
it greatly depends on
  • what is the router expected to do,
  • if you mean 600Mbps full duplex (I mean 600Mbps inbound to outbound + 600Mbps outbound to inbound) or not,
  • required scalability.
If the router is just routing packets I think you can use the 4451 otherwise  try to have a look to the following link to have an idea of performance Vs feature but remember to use these results just as a rule of thumb because the real throughput in your scenario could be different because it depends on the way the features are implemented, I mean: NAT is NAT but  you can configure a single static NAT ore  a large PAT architecture  http://miercom.com/pdf/reports/20150817.pdf
An alternative  is ASR 1001-X
Hope this help,
enrico
Hi Enrico,
Thanks for your suggestion.
It will be working on Full duplex and used for Internet access of multiple location offices as a centralized gateway.
Throughput aggregation of 4351 in the cisco data sheet mention it can handle 1Gbps to 2 Gbps.
Whether the through put indicates the speed at which the port operates or the speed the port can handle the traffic.
Hari.
You can try this tool to select the proper router for your requirements:
http://3c3cc.com/c/dam/assets/prod/routers/cisco-router-selector/index.html
Please rate the comment if it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
It increases the performance from base performance to 2 Gbps
Bye,
enrico
PS: please rate if useful
Leo Laohoo
Duplicate thread.
Kindly post all response(s) into the main thread (HERE).
