Router/Switch after Firewall
ISSM
My current setup that's working is ISP > Firewall (DHCP Server/NAT/ACL) > Switch > Computers.
I want to put a Router between the Firewall and Switch even though I know it's not needed, but we paid for it.
Firewall "Inside" > Router's G0/0/0 and G0/0/1 to Switch.  Router and Switch are open with no configuration.
All computers gets an IP address, but no access to the internet.  On router, I did an ip route 0.0.0.0 0.0.0.0 192.160.0.1 (Firewall Gateway IP).
What am I doing wrong?
37 Replies 37
So I got the DHCP server working on the router and my clients gets an ip address from 192.168.1.0/24.  However, no internet access.  I think I have an issue with routing between Cisco FTDand Router.
Our windows server (DC/DNS) is on another subnet...192.168.0.0/25.  Is this an issue?
I have attached the Router/FTD running config.
nat (inside,outside) source dynamic any-ipv4 interface
nat (inside,inside) source dynamic any-ipv4 Router_to_firewall
it not DNS issue it NATing
you here only NAT the subnet between FTD and router
you need to add object-group for LAN subnet and then add dynamic NAT under it
So I added an object-group for LAN subnet (192.168.1.0/24).  What would be the original and translated packets for source/destination address?
Would this be nat (inside,outside) source dynamic Lan Subnet interface?
LAN subnet is 192.168.1.0 or 192.168
0.0 ??
192.168.1.0
Go head add 192.168.1.0 object group and config NAT
Interface will be (inside,outside)
Hello @ISSM,
On your FTD, based on the conf of your post [‎05-23-2023 06:43 AM]
[route inside 0.0.0.0 0.0.0.0 192.168.1.1 10]
is not [route inside 0.0.0.0 0.0.0.0 192.168.0.2 10] ?
Best regards
 "What am I doing wrong?"
 "...I want to put a Router between the Firewall and Switch even though I know it's not needed, but we paid for it."
Basically that´s what you are doind wrong.
