Router/Switch after Firewall
ISSM
My current setup that's working is ISP > Firewall (DHCP Server/NAT/ACL) > Switch > Computers.
I want to put a Router between the Firewall and Switch even though I know it's not needed, but we paid for it.
Firewall "Inside" > Router's G0/0/0 and G0/0/1 to Switch.  Router and Switch are open with no configuration.
All computers gets an IP address, but no access to the internet.  On router, I did an ip route 0.0.0.0 0.0.0.0 192.160.0.1 (Firewall Gateway IP).
What am I doing wrong?
37 Replies 37
the SW is L2 it normal not show IP assign to client.
the SW L2 show only MAC address
Sorry, I meant the router is not showing any IP addresses assigned.  Client on switch is stating can't contact dhcp server.
Do I need to run command on Int G/0/0/1 on router - Switchport access Direct-Internet, which is the name of my DHCP pool?
OK @ISSM
Does the client have an ip add?
For the switch it's a normal situation as explained @MHM Cisco World
Best regards
Client does not get an ip address because it said it can't contact DHCP server.  I will try to export router config and post it here.
as I mention before check the reachability.
the client NOT connect to DHCP server
the client send broadcast, the router receive this broadcast and convert it to unicast and send it to ASA (DHCP server)
the ASA must have route to LAN to make it reply to DHCP request (from router)
CISP.Router#show run
Building configuration...
Current configuration : 6755 bytes
! Last configuration change at 15:37:01 UTC Mon May 22 2023
version 17.6
! Call-home is enabled by Smart-Licensing.
service call-home
platform qfp utilization monitor load 80
platform punt-keepalive disable-kernel-core
hostname xxx
boot-start-marker
boot-end-marker
enable secret xxx
enable password!
no aaa new-model
 --More--
*May 22 15:37:01.917: %SYS-5-CONFIG_I: Configured from console !        e
ip dhcp bootp ignore
no ip dhcp conflict logging
ip dhcp excluded-address 192.168.0.0 192.168.0.5
ip dhcp excluded-address 192.168.0.245 192.168.0.255
ip dhcp pool Direct-Internet
 network 192.168.0.0 255.255.255.0
 default-router 192.168.0.1
 dns-server 192.168.0.254 192.168.0.253
login on-success log
subscriber templating
crypto pki trustpoint TP-self-signed-xxx
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-xxx
 revocation-check none
 rsakeypair TP-self-signed-xxx
crypto pki trustpoint SLA-TrustPoint
 enrollment pkcs12
 revocation-check crl
license udi pid C8300-1N1S-4T2X sn
memory free low-watermark processor 67522
diagnostic bootup level minimal
username
username xxx privilege 15 secret xxx
redundancy
 mode none
interface GigabitEthernet0/0/0
 ip address 192.168.0.250 255.255.255.0
 negotiation auto
interface GigabitEthernet0/0/1
 no ip address
 negotiation auto
interface GigabitEthernet0/0/2
 no ip address
 shutdown
 negotiation auto
interface GigabitEthernet0/0/3
 no ip address
 shutdown
 negotiation auto
interface TenGigabitEthernet0/0/4
 no ip address
 shutdown
 negotiation auto
interface TenGigabitEthernet0/0/5
 no ip address
 shutdown
 negotiation auto
ip http server
ip http authentication local
ip http secure-server
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.0.2
the router is the DHCP server for client not the ASA ?
if Yes then you need only one interface with IP 192.168.0.1 <<-
NOTE:- no need ip helper
I moved the DHCP server to router from ASA.  FIrewall's IP is now 192.168.0.2 and Router is 192.168.0.1.
I will share the topology with IP need
can you re-share the config here
Attached.
Rich R
That can only work if you use bridging between the router and firewall.  This is using the router as a switch or bridge not as a router!
If you want to use the router as a router then they need to be on different subnets.
If you set up bridging (or use switchports) to do that with them in the same subnet then you'll need to set the default gateway to be the firewall 192.168.0.2.
What model of router are you using?
Share the config so we can see what you've configured? (attach as text file - don't paste here)
It's a pitty to not use a router for what is doing so well.
"If you want to use the router as a router then they need to be on different subnets" +1
Best regards
Please see attached for my router configt.  It's a Cisco C8300 router.
