router that does not route
armandschindler
I was CCNP but for sure a little bit too long to be efficient in routing. We received a new router (CISCO2901/K9) but I’m not able to use it.
Very easy scenario : 2 subnet : 1 WAN and 1 LAN.
Cisco router configuration :
version 15.2
no service pad
service password-encryption
hostname int-xxxxx
boot-start-marker
boot system flash0:c2900-universalk9_npe-mz.spa.152-4.m6a.bin
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
memory-size iomem 10
ip domain name xxxxx.xxx
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip cef
no ipv6 cef
crypto pki trustpoint TP-self-signed-13405798
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-13405798
 revocation-check none
crypto pki certificate chain TP-self-signed-13405798
 certificate self-signed 01
  3082024E 308201B7 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
        quit
license udi pid CISCO2901/K9 sn FTX180883V6
username cisco privilege 15 password 7 0822455D0A16
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 ip address 62.119.117.65 255.255.255.224
 duplex auto
 speed auto
interface GigabitEthernet0/1
 ip address 26.130.21.150 255.255.255.252
 duplex full
 speed 100
ip forward-protocol nd
no ip http server
ip http access-class 23
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 26.130.21.149
ip route 62.119.117.96 255.255.255.224 62.119.117.66
access-list 23 permit X.X.X.X 0.0.0.255
access-list 23 permit X.X.X.X 0 0.0.0.255
snmp-server community XXXXXXXX RO 23
snmp-server enable traps entity-sensor threshold
control-plane
banner login ^CCCCCCCCCCCCCC
--   All logins are logged   --   Private and restricted access   --
--                       Property of XXXXXX                        --
^C
line con 0
 login local
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 access-class 23 in
 privilege level 15
 login local
 transport input ssh
scheduler allocate 20000 1000
End
int-xxxx#sh ver
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9_NPE-M), Version 15.2(4)M6a, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Tue 15-Apr-14 09:45 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
int-xxxx uptime is 3 hours, 31 minutes
System returned to ROM by reload at 21:08:06 UTC Fri Jun 27 2014
System image file is "flash0:c2900-universalk9_npe-mz.spa.152-4.m6a.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2901/K9 (revision 1.0) with 475136K/49152K bytes of memory.
Processor board ID FTX180883V6
2 Gigabit Ethernet interfaces
1 terminal line
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO2901/K9          XXXXXX
Technology Package License Information for Module:'c2900'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      None          None           None
uc            None          None           None
data          None          None           None
Desktop Configuration :
Ethernet adapter Ethernet:
   Connection-specific DNS Suffix  . :
   IPv4 Address. . . . . . . . . . . : 62.119.117.71
   Subnet Mask . . . . . . . . . . . : 255.255.255.224
   Default Gateway . . . . . . . . . : 62.119.117.65
Issue Description :
I’m able to ping internet from my router :
int-xxxx#ping 8.8.8.8
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
From my desktop I’m able ton ping LAN and WAN interface of the router :
C:\Users\ars16537>ping 62.119.117.65
Pinging 62.119.117.65 with 32 bytes of data:
Reply from 62.119.117.65: bytes=32 time=1ms TTL=255
C:\Users\ars16537>ping 26.130.21.150
Pinging 26.130.21.150 with 32 bytes of data:
Reply from 26.130.21.150: bytes=32 time=1ms TTL=255
But not internet of the router next hop :
C:\Users\ars16537>ping 157.130.21.149
Pinging 26.130.21.149 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
So the router doesn’t want routing. Any Idea ?
Hello The first part of your post -show the defaults routes and wan-LAN interfaces? The second part show a IP address/subnet mask-default-gateway - Is all the configuration off the same device It hard to make out? Also can you ping your ISPs next hop from the router? Your static route back into your LAN points to a .66 ip but the second half of the config shows a .71 ip Can you clarify what configuration is related to what device? Res Paul
Kind Regards
Paul
Hi armandschindler,
I think you are missing something. make sure your lan interfaces are public ip. May be not, so your isp have no information about these routes 62.119.117.64 /27 eventually ping fail.
In this case you need nat on this router.
ping from your router is successful because Its public ip and your isp has information how to route back.
kazim
