Router types description
markagregory
Visitor
I would like to find details about routers and the different types of routers. Is there something in ppt or pdf that explains the difference between edge routers and core routers?
regards, Mark
7 Replies 7
spremkumar
Level 11
Level 11
Hi Mark
Hope this helps..
regds
Hi Mark,
Kindly check this document:
Cisco Router Guide Cisco Router Guide
http://www.cisco.com/application/pdf/en/us/guest/products/ps5855/c1031/cdccont_0900aecd8019dc1f.pdf
HTH,
Mohammed Mahmoud.
thank you for pointing me at this document. Is there another document like this for the service provider routers?
regards,
mark
Hi there,
Here you go:
http://www.cisco.com/en/US/products/hw/routers/index.html
HTH, please rate if it does help,
Mohammed Mahmoud.
I have been to that page and cannot find anything in ppt or pdf that lists all the details for the 7600, 10000, 12000, CRS-1 products.
I found the cisco router guide which covers all of the SMB, enterprise and head officer routers. Now I need something that covers all of the service provider routers...
I'm really interested in ppt but pdf is ok.
regards
Mark
Hi Mark,
Always remember the following:-
1. If you want to know the detailed information about the product quickly, please view the Data Sheets under any particular product e.g. following is the data sheets for 4500 Series Switch
2. If you want to know the configuration please visit the UniverCD home page at
http://cisco.com/univercd
Please rate,
Kind Regards,
Wilson Samuel
