router via access server 2500 i want to backup startup-con
ciscoinpushto
I am using access server 2500, i am accessing these router via access server 2500 i want to backup startup-conf o of these routers 2600,3600,and so on. how can i do this
Richard Burts
If you are accessing routers such as as 2600 and 3600 using an access server 2500 then I am assuming that you have console connections to these routers and probably not Ethernet network connectivity. Is this correct?
In that case the way that you would back up the startup configurtation would be to do show startup and then copy and paste the output into a text file.
Rick
Rick
Richard Burts
Rick
Rick
