router will not bootup
Charles Hill
I have a 2801 router with ios c2801-ipvoice-mz.124-17b.bin with 1 vwic 1MFT-
T1. It appears to be in a loop. I have tried doing a break sequence to access romon, but no luck. I have pasted the router's output.
Copyright (c) 2006 by cisco Systems, Inc.
Correcting the primary nv_flash
PLD version 0x10
GIO ASIC version 0x127
c2801 platform with 131072 Kbytes of main memory
Main memory is configured to 64 bit mode with parity disabled
Readonly ROMMON initialized
System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
PLD version 0x10
PLD version 0x10
PLD version 0x10
tomocisco
what exactly happens when you try to break into Romon?
can you access the router using via web browser using CDM?
Tom
no response when attempting a break sequence. Also unable to browse to the router.
Cisco overnighted a replacement router, which resolved the trouble.
