Router with 3 LAN interfaces and 4 serial interfaces
w.alzeadat
Hi every one,
Please i need Cisco router has at least 3 LAN interfaces and 4 serial interfaces.
any suggestion about model?
6 Replies 6
Mark Elsen
 - Not a direct reply but these info's may help :
            https://www.cisco.com/c/en/us/products/routers/router-selector.html
            https://www.cisco.com/c/en/us/solutions/small-business/networking/routers.html
 M.
thanks but i didn't get any router support 3 LAN interfaces and 4 serial interfaces.
Leo Laohoo
What is the budget?
This is for research purposes, so its not important.
you probably need a modular router in order to support an HWIC-4T (4 serial interfaces) and an additional 1-NM-FE (FastEthernet) port.
Have a look at the link below and check for Table 5, which lists all routers that support the HWIC-4T. I think all of them also support an additional 1-NM-FE.
https://www.cisco.com/c/en/us/products/collateral/interfaces-modules/1800-2800-3800-series-16-port-async-high-speed-wan-interface-card/product_data_sheet0900aecd80274416.html
thanks bro
