Router with dual ISP
skmdimran
Dear Concern,
Please find attachment of network diagram the network diagram for details.
  1. Two           ISP( for internet) links are connect      in the      router ( 2811).
  2. Public IP of ISP 1 are using      between Router and ASA.
  3. VPN has been configured with      ISP 1 IP address
  4. Three           zone ( Outside , DMZ , Inside) specified on the ASA.
  5. In      DMZ      , there are two proxy server ( proxy 1 ,      proxy 2) .
  6. Branch           user will use proxy server 1  and      Head      office will use proxy 2.
In the above scenario , is it possible to fulfill the following requirements
  1. Proxy1 will use ISP 1 and      proxy 2 will use ISP 2.
  2. If ISP1 goes down then proxy 1 will use ISP      2 for internet ( not for VPN )And vice versa.
Please help me how I will configure the router.
Imran
Haris P
Level 4
Level 4
Dear Imran ,
This scenario is possible with IOS NAT load balancing with Optimized Edge routing . You can go to the below link for more details
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a00808d2b72.shtml
Since you are using public IP's of two ISP's ,there might be some limitaion due to this as the IP's are related with ISP connection .
Haris P
