interface bonding
dear friend how can divide the traffic between two port using bonding ... between router mokrotik and cisco switch ???
Peter Paluch
Hi Tariq,
The Mikrotik router boards are running GNU/Linux, aren't they? It should not be a problem to create an EtherChannel between a Cisco switch and the router board. I cannot tell you the exact steps how to configure the bonding interface on the router board - I am not familiar with its configuration syntax - but generally, you should use the LACP method of negotiating an EtherChannel. At all costs avoid using the EtherChannel without a negotiation protocol. On the Cisco switch, configuring two or more (up to eight) ports to be joined in an EtherChannel, you can use the following command:
interface range fa0/1 - 2
channel-group 1 mode active
This command will create the Port-channel1 interface and group the Fa0/1 and Fa0/2 under it. The "mode active" will activate the LACP Active mode on the channel group. Note that both Fa0/1 and Fa0/2 must be identically configured with all other settings (access/trunk mode, allowed VLANs, speed, duplex, native VLANs, etc.).
Best regards,
Peter
