router won't give connecton to my switch with vlans configured to it
Ryan2003
Hello everybody,
The last 3 days ive been configuring a cisco 1941 router and a cisco catalyst 3750 switch for learning purposes. after configuring the router, i wanted to configure the switch with vlans. only the problem is that when i connect the switch with the router i wont get an connection. i've looked in every corner on the internet but can't vind any solution. down below ive listed my router and switch configurations. All help is appreciated and i want to thank everybody in advance.
NOTE: Because this is for learning purposes, mistakes were made, so some lines of text are wrong, so keep it in mind.
router config:
 Current configuration : 2367 bytes
version 15.4
hostname ITSR1
boot-start-marker
boot-end-marker
enable secret 5 $1$q3Zq$sQNEwBPwVkSe.eGCo2XoF.
no aaa new-model
ip dhcp excluded-address 192.168.150.1 192.168.150.50
ip dhcp pool lan-pool
network 192.168.150.0 255.255.255.0
default-router 192.168.150.1
dns-server 8.8.8.8
no ip domain lookup
ip domain name ITsolutions.nl
ip cef
no ipv6 cef
cts logging verbose
license udi pid CISCO1941/K9 sn FCZ201760HM
username
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description Broadband internet
mac-address 0844.0322.0133
ip address dhcp
ip access-group 1 in
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
description ITsoluctions LAN
ip address 192.168.150.1 255.255.255.0
ip nat inside
duplex auto
speed auto
interface GigabitEthernet0/1.10
encapsulation dot1Q 10
ip address dhcp
ip nat inside
interface GigabitEthernet0/1.20
encapsulation dot1Q 20
ip address dhcp
ip nat inside
interface GigabitEthernet0/1.99
encapsulation dot1Q 99
ip address dhcp
ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 100.100.100.2
ip route 0.0.0.0 0.0.0.0 192.168.100.2
ip route 0.0.0.0 0.0.0.0 192.168.0.1
ip route 200.200.200.0 255.255.255.0 100.100.100.2
access-list 1 permit 0.0.0.255
access-list 1 permit 192.168.150.0 0.0.0.255
access-list 1 permit 0.0.0.1 255.255.255.0
access-list 1 permit any
access-list 10 permit 192.168.0.0 0.0.0.255
control-plane
banner motd ^C
Pas mijn instellingen niet aan!^C
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password
login local
transport input ssh
scheduler allocate 20000 1000
end
switch config:
Current configuration : 2590 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname SW40Server
username admin password 0 cisco
no aaa new-model
switch 1 provision ws-c3750g-24ts
ip subnet-zero
ip domain-name
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface GigabitEthernet1/0/1
switchport access vlan 10
switchport mode access
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
switchport access vlan 20
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
switchport access vlan 99
switchport trunk allowed vlan 10,20
switchport mode trunk
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface Vlan1
no ip address
shutdown
interface Vlan10
ip address dhcp
interface Vlan20
ip address dhcp
interface Vlan99
ip address dhcp
ip default-gateway 192.168.150.1
ip classless
ip http server
control-plane
line con 0
line vty 0 4
no login
line vty 5 15
no login
end
Thank you for the help.
12 Replies 12
make the changes marked in bold to your switch configuration.
The subinterfaces on your router are set to 'dhcp'. Where is the DHCP server ?
version 12.2
no service pad
hostname SW40Server
no aaa new-model
ip subnet-zero
ip domain-name
no file verify auto
--> interface Vlan1
--> ip address 192.168.150.2 255.255.255.0
--> no interface Vlan10
ip address dhcp
--> no interface Vlan20
ip address dhcp
--> no interface Vlan99
ip address dhcp
ip classless
ip http server
control-plane
line con 0
line vty 0 4
no login
line vty 5 15
no login
end
Hello Sir,
At the moment there is no dhcp server, but i was planning to implemt it later on. Ive changed the setting, but i still get a ''unknown network, no internet'' error on my laptop.
Thanks in advance,
Ryan
with your current configuration (and the changes I suggested), you will only be able to access the router if your laptop is connected to the switch on a port that is configured like this:
spanning-tree portfast
Would you post the output of these commands on the switch
show cdp neighbor
show interface status
show interface trunk
And would you tell us which switch interface connects to the router and which switch interface connects to your laptop.
Rick
Dear Mr Burts,
Here are the following outputs:
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone
Device ID Local Intrfce Holdtme Capability Platform Port ID
ITSR1.ITsolutions.nl
Gig 1/0/23 129 R B S I CISCO1941/Gig 0/1
Port Name Status Vlan Duplex Speed Type
Gi1/0/1 connected 10 a-full a-1000 10/100/1000BaseTX
Gi1/0/2 notconnect 10 auto auto 10/100/1000BaseTX
Gi1/0/3 notconnect 10 auto auto 10/100/1000BaseTX
Gi1/0/4 notconnect 10 auto auto 10/100/1000BaseTX
Gi1/0/5 notconnect 10 auto auto 10/100/1000BaseTX
Gi1/0/6 notconnect 10 auto auto 10/100/1000BaseTX
Gi1/0/7 notconnect 10 auto auto 10/100/1000BaseTX
Gi1/0/8 notconnect 10 auto auto 10/100/1000BaseTX
Gi1/0/9 notconnect 10 auto auto 10/100/1000BaseTX
Gi1/0/10 notconnect 10 auto auto 10/100/1000BaseTX
Gi1/0/11 notconnect 10 auto auto 10/100/1000BaseTX
Gi1/0/12 notconnect 10 auto auto 10/100/1000BaseTX
Gi1/0/13 notconnect 20 auto auto 10/100/1000BaseTX
Gi1/0/14 notconnect 20 auto auto 10/100/1000BaseTX
Gi1/0/15 notconnect 20 auto auto 10/100/1000BaseTX
Gi1/0/16 notconnect 20 auto auto 10/100/1000BaseTX
Gi1/0/17 notconnect 20 auto auto 10/100/1000BaseTX
Gi1/0/18 notconnect 20 auto auto 10/100/1000BaseTX
Gi1/0/19 notconnect 20 auto auto 10/100/1000BaseTX
Gi1/0/20 notconnect 20 auto auto 10/100/1000BaseTX
Gi1/0/21 notconnect 20 auto auto 10/100/1000BaseTX
Gi1/0/22 notconnect 20 auto auto 10/100/1000BaseTX
Gi1/0/23 connected trunk a-full a-1000 10/100/1000BaseTX
Gi1/0/24 notconnect 99 auto auto 10/100/1000BaseTX
Gi1/0/25 notconnect 99 auto auto Not Present
Gi1/0/26 notconnect 99 auto auto Not Present
Gi1/0/27 notconnect 99 auto auto Not Present
Gi1/0/28 notconnect 99 auto auto Not Present
Port Mode Encapsulation Status Native vlan
Gi1/0/23 on 802.1q trunking 1
Port Vlans allowed on trunk
Gi1/0/23 10,20
Port Vlans allowed and active in management domain
Gi1/0/23 10,20
Port Vlans in spanning tree forwarding state and not pruned
Gi1/0/23 10,20
As for you're question the router and the switch are connected thrue interface gigabyte 1/0/23 as this is my trunking port. As for my laptop, this is connected thrue interface gigabyte 1/0/1.
Kind regards,
Ryan
Dear Mr Pauwens,
I have tried you're suggestions on the switch. after troubleshooting for a while i still cant get an connection. i've put the spanning-tree porstfast in default. Does this cause the issue that i dont get an connection?
Kind regards,
Ryan
make sure your ports look exactly like below:
description Uplink to Router
description Laptop
Also, post the running configs of both the router and the switch again, with the changes you have implemented.
Dear Mr Pauwens,
my configurations are listed below. I have applied these setting but with no succes. Am i doing something wronge with the spanning-three portfast. This is new to me, so this may cause it.
Switch:
Building configuration...
Current configuration : 2552 bytes
version 12.2
no service pad
hostname SW40Server
no aaa new-model
ip subnet-zero
ip domain-name Leerdock.local
no file verify auto
spanning-tree portfast default
interface Vlan1
ip classless
ip http server
control-plane
line con 0
line vty 0 4
no login
line vty 5 15
no login
end
Router:
Current configuration : 2437 bytes
! Last configuration change at 11:49:18 UTC Mon Oct 12 2020 by ryan
version 15.4
hostname ITSR1
boot-start-marker
boot-end-marker
no aaa new-model
dns-server 8.8.8.8
no ip domain lookup
ip cef
no ipv6 cef
cts logging verbose
username
redundancy
no ip address
shutdown
ip address dhcp
ip nat outside
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
ip address dhcp
ip nat inside
ip address dhcp
ip nat inside
ip address dhcp
ip nat inside
no ip http server
control-plane
banner motd ^C
Passen Sie meine Einstellungen nicht an!^C
line con 0
line aux 0
line 2
no exec
stopbits 1
line vty 0 4
password
login local
transport input ssh
ntp server
kind regards,
Ryan
you have not implemented the changes I suggested. Spanning-tree portfast is not the problem. The problem is that the port conneced to the laptop is an access port in Vlan 10. There is no ip address on the subinterface of the router for Vlan 10. With your current router configuration, you can only get an IP address from Vlan 1. Change the settings to:
--> no switchport access vlan 10
Ryan
Thank you for the outputs that I requested. They do confirm that there is connectivity between router and switch and do confirm that trunking is configured and is operating correctly.
@Georg Pauwen has correctly identified that there is no IP address on the router for vlan 10 (or for vlan 20). Both router subinterfaces are configured to use DHCP to get an address. But where would that DHCP come from? The solution that he suggests, to configure the switch port where PC connects to be in vlan 1 would solve the issue for that device. But it does not address the fundamental issue for vlan 10 and 20. Either you need to provide something that would provide DHCP addressing for those interfaces or you need to remove the DHCP from those router interfaces and assign IP addresses and masks for the interfaces. This is a much better long term solution.
Rick
One IP address for each sub interface in router.
Dear HMH,
thank you for your reply, but i have already tried this, and it didint work. Beside i was planning to add more divices so i think 1 IP address wont work.
Kind regards,
Ryan
