Router
ishwar
I need router which support upto 4 ethernet wan interface .which series of cisco router is appropriate for it.
spremkumar
Level 9
Level 9
hi
I would better suggest to check out the datasheets of each model starting from 1800 to find out the best bet for ur network.
Again which can be cost effective and can meet/support all the required features in ur network.
http://cisco.com/en/US/products/hw/routers/index.html
regds
tcordier
you can also use the Cisco Product Advisor:
http://www.cisco.com/warp/public/779/smbiz/service/advisor/
HTH, Thomas
