Router
edusilveira
Router Cisco 1750 supports WIC-4ESW interface?
Router: CISCO 1750
IOS : c1700-k9sy-mz.122-12
mohammedmahmoud
Level 11
Level 11
Yes it does:
http://www.cisco.com/en/US/products/hw/routers/ps221/products_data_sheet09186a00801c749d.html
http://www.cisco.com/en/US/products/hw/modules/ps2641/products_module_installation_guide_chapter09186a008007cb78.html
But i guess that you'll need an IOS upgrade:
First Cisco IOS Software release - Cisco IOS Software Release12.3(2)XC (this is an early deployment release that is merged into Cisco IOS Software Release 12.4T)
Minimum feature sets - Cisco IOS IP or IP Basic
HTH,
Mohammed Mahmoud.
Ok , but i used Cisco Software Advisor, Product advisor, and return that only
1751 / 1721 / 1760 supports this interface module. Cisco 1750 supports?
Thanks.
Yes according to Cisco router guide all the 1700 series routers support the above module but requires atleast 12.3(4)YB
Narayan
