Routes learned from EIGRP not showing in BGP routing table
luqman_khalid
This is basic MPLS-VPN LaB i am practicing on GNS3. topology Diagram is attached.
I am unable to ping from PE(R-2) to PE(R-4). routes are showing in neighbor table of BGP but not in routing table.
Please help. I am attaching config files of PE(R2) , PE (R4) and P (R3) routers.
#bgp #Eigrp #MPLS #MPLSVPN #MP-BGP
Giuseppe Larosa
Hello @luqman_khalid ,
in order to build a working configuration in the MPLS forwarding plane you need ip ospf network point-to-point to advertise in OSPF a /24 loopback address. Otherwise there is a mismatch between  IGP that advertises a /32 and LDP that advertises a /24 and instead of POP action you get show mpls forwarding action UNTAGGEd this breaks the MPLS L3 VPN connectivity.
interface Loopback0
 ip address 4.4.4.4 255.255.255.0
ip ospf network point-to-point !
Do the the same on R2 PE and on P nodes this is  a specific issue of OSPF when dealing with loopback interfaces with subnet masks different then 255.255.255.255
Hope to help
Giuseppe
5 Replies 5
at first glance, you are missing the 'bgp redistribute-internal' command under the BGP process on R2 and R4...
Still not working.
same result. is there any limitation of GNS ?
post the full configs of all 5 routers so we can lab this...
Giuseppe Larosa
interface Loopback0
Hope to help
Giuseppe
Thank you dear , it worked by two different methods.
1: converting Loopback address from /24 to /32.
2: solution proposed by You.
@Giuseppe Larosa
