Cisco C8194g router cannot access internet from vlan1
The Cell0 interface is working fine, pinging 8.8.8.8 without any problems.but from vlan1 network 192.168.1.0, getting dhcp with ip address and dns but cannot reach 8.8.8.8 from connected PC Vlan1
kindly help me ...
the configurations below
ip cef
ip dhcp pool ahmad
import all
network 192.168.1.0 255.255.255.0
dns-server 208.67.222.222 8.8.8.8
default-router 192.168.1.1
ip dhcp-server 192.168.1.0
no ipv6 cef
chat-script lte "" "AT!CALL1" TIMEOUT 30 "OK"
license udi pid C819G-4G-G-K9 sn FCZ1724C2NY
vtp mode t! t
controller Cellular 0
interface Cellular0
ip address negotiated
ip nat outside
ip virtual-reassembly in
encapsulation slip
dialer in-band
dialer string lte
dialer-group 1
async mode interactive
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface Fastt3
no ip address
interface GigabitEthernet0
no ip address
shutdown
duplex auto
speed auto
interface Serial0
no ip address
shutdown
clock rate 2000000
interface Vlan1
ip nat inside
ip forward-protocol nd
no ip erver
no ip http secure-server
ip nat inside source list NAT interface Cellular0 overload
ip route 0.0.0.0 0.0.0.0 Cellular0
ip access-list extended NATp 192.0.0.0 0.0.0.255 any
permit ip 192.168.1.0 0.0.0.255 any
dialer-list 1 protocol ip permit
control-plane
line con 0
no modem enable
l
line 2
no activation-character
no exec
transport preferred none
transport input all
stopbits 1
line 3
exec-timeout 0 0
script dialer lte
modem InOut
no exec
rxspeed 100000000
txspeed 50000000
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
who is your ISP ? Make sure you don't need any authentication, otherwise you need to use a dialer interface.
For now, make the changes marked in bold:
ip cef
--> ip dhcp excluded-address 192.168.1.1
ip dhcp pool ahmad
import all
--> no ip dhcp-server 192.168.1.0
no ipv6 cef
vtp mode t! t
interface Cellular0
ip nat outside
encapsulation slip
dialer in-band
dialer string lte
dialer-group 1
no ip address
no ip address
no ip address
interface Fastt3
no ip address
no ip address
shutdown
duplex auto
speed auto
interface Serial0
no ip address
shutdown
clock rate 2000000
interface Vlan1
ip nat inside
no ip erver
--> ip nat inside source list 1 interface Cellular0 overload
--> access-list 1 permit 192.168.1.0 0.0.0.255
control-plane
line con 0
no modem enable
l
line 2
no exec
transport input all
stopbits 1
line 3
exec-timeout 0 0
script dialer lte
modem InOut
no exec
rxspeed 100000000
txspeed 50000000
line vty 0 4
login
transport input all
end
ip cef
ip dhcp pool ahmad
import all
no ipv6 cef
vtp mode t! t
interface Cellular0
ip nat outside
encapsulation slip
dialer in-band
dialer string lte
dialer-group 1
no ip address
no ip address
no ip address
interface Fastt3
no ip address
no ip address
shutdown
duplex auto
speed auto
interface Serial0
no ip address
shutdown
clock rate 2000000
interface Vlan1
ip nat inside
no ip erver
control-plane
line con 0
no modem enable
l
line 2
no exec
transport input all
stopbits 1
line 3
exec-timeout 0 0
script dialer lte
modem InOut
no exec
rxspeed 100000000
txspeed 50000000
line vty 0 4
login
transport input all
end
