Routing across Frame-Relay network to VPN?
peterkley
I have about 10 sites on a frame network, connecting to the main site thru S0/0. There are 4 sites using DSL to connect to the WAN ip of the main site, using tunnels. The main site has E0/0 for the WAN link and a public IP, and FA1/0 for the LAN.
There is a VPN on the LAN at 10.159.140.2 (FA1/0 is 10.159.140.1)
I have this entry to route traffic to a specific web site that is on the VPN:
ip route 10.28.0.0 255.255.0.0 10.159.140.2
If I type in 10.28.98.35 in a web browser on the LAN, traffic works just fine.
However, anywhere outside the LAN, either on the frame or via tunnel, a traceroute shows it hitting the main site ip and quitting. Any suggestions?
Here's a condensed version of what's on the main site router (I assume the problem is there since the trace does hit it). I also edited out the public addresses to protect the innocent!
interface Tunnel0
description Citris Heights
ip address 10.159.100.21 255.255.255.252
ip access-group 102 in
no ip directed-broadcast
ip nat inside
ip summary-address eigrp 10 10.159.0.0 255.255.0.0
tunnel source Ethernet0/0
tunnel destination xxx.xxx.xxx.xxx
tunnel key 15146
interface Ethernet0/0
ip address xxx.xxx.xxx.xxx 255.255.255.248
ip access-group 101 out
ip nat outside
no ip route-cache
no ip mroute-cache
no cdp enable
interface Serial0/0
description ASI Circuit ID XXX
bandwidth 128
no ip address
encapsulation frame-relay
no ip route-cache
no ip mroute-cache
logging event subif-link-status
logging event dlci-status-change
no fair-queue
service-module t1 timeslots 1-24
frame-relay traffic-shaping
frame-relay lmi-type ansi
interface Serial0/0.16 point-to-point
description Orangevale
bandwidth 56
ip address 10.159.100.61 255.255.255.252
ip nat inside
no ip route-cache
no ip mroute-cache
no cdp enable
frame-relay interface-dlci 16
class 56kcir
interface FastEthernet1/0
ip address 10.159.140.1 255.255.255.0
ip access-group 103 in
ip nat inside
no ip route-cache
no ip mroute-cache
no cdp enable
router eigrp 10
redistribute static
passive-interface Ethernet0/0
passive-interface FastEthernet1/0
network 10.0.0.0
no auto-summary
eigrp log-neighbor-changes
ip nat inside source list 1 interface Ethernet0/0 overload
ip nat inside source static tcp 10.159.188.14 22 interface Ethernet0/0 22
ip nat inside source static tcp 10.159.188.13 3389 interface Ethernet0/0 40411
ip nat inside source static interface Fastethernet1/0 8080 interface Serial0/0.21 8080
ip classless
ip route 0.0.0.0 0.0.0.0 <outside internet>
peterkley
Here is the rest...
map-class frame-relay 56kcir
no frame-relay adaptive-shaping
frame-relay cir 56000
frame-relay bc 1000
frame-relay mincir 56000
frame-relay priority-group 1
map-class frame-relay 384kcir
frame-relay cir 384000
frame-relay bc 3840
frame-relay be 0
frame-relay mincir 384000
map-class frame-relay 128kcir
frame-relay cir 128000
frame-relay bc 1280
frame-relay be 0
frame-relay mincir 128000
map-class frame-relay 384cir
access-list 1 permit 10.159.0.0 0.0.255.255
access-list 101 deny ip any 10.0.0.0 0.255.255.255
access-list 101 permit ip any any
access-list 102 permit ip 10.159.135.0 0.0.0.255 any
access-list 102 permit ip 10.159.100.20 0.0.0.3 any
access-list 102 deny ip any any
access-list 103 deny udp any any eq netbios-ns
access-list 103 deny udp any any eq netbios-dgm
access-list 103 permit ip any any
access-list 104 permit ip 10.159.153.0 0.0.0.255 any
access-list 104 permit ip 10.159.100.64 0.0.0.3 any
access-list 104 deny ip any any
access-list 105 permit ip 10.159.180.0 0.0.0.255 any
access-list 105 permit ip 10.159.100.88 0.0.0.3 any
access-list 105 deny ip any any
access-list 106 permit ip 10.159.167.0 0.0.0.255 any
access-list 106 permit ip 10.159.100.56 0.0.0.3 any
access-list 106 deny ip any any
access-list 150 permit udp any any range 5000 5070
access-list 150 permit udp any range 5000 5070 any
access-list 150 permit udp any any eq 5567
access-list 150 permit udp any eq 5567 any
access-list 150 permit tcp any any eq 5566
access-list 150 permit tcp any eq 5566 any
access-list 150 permit tcp any any eq 5570
access-list 150 permit tcp any eq 5570 any
access-list 150 permit udp any any eq 16384
access-list 150 permit udp any eq 16384 any
priority-list 1 protocol ip high list 150
unfortunately I am not so sure about source and destination IPs, but are you sure your access-lists do allow the traffic you intend to send through the tunnel?
As a step in troubleshooting remove the access-lists from the tunnel and other interfaces (reapply them afterwards!). Is the problem then still there?
Hope this helps
Martin
There are some things about Peter's explanation of the situation and of the problem that I have not completely understood. But I wonder if his problem is in the configuration of the VPN. I notice that there is no VPN configuration in the configuration parts that he posted. He says that the VPN is on 10.159.140.2 and I wonder what kind of device that is, and if it might be another router. I would guess from the symptoms that the VPN configuration on 10.159.140.2 might permit traffic with a source address in the subnet of that interface but not permit traffic with source address of other parts of the network. And of course there is the possibility that the device at 10.159.140.2 (or devices on the other end of the VPN) do not have routes back to the addresses of the other part of his network.
Perhaps Peter can comment on this.
Rick
Rick
Yes, the VPN is a separate device. Sadly I don't have any information on what that device is or how it is set up.
But your email helped me to realize that the problem is more likely in the VPN rather than the route tables. I will also remove the access-lists that apply and see what happens.
Thanks!
