Routing and switching with Cisco Catalyst 3550
bogpsycho
Hello everybody ! I use a Catalyst 3550 for routing and switching my clients to the Internet. I established a BGP session with an ISP which give me a default route for Global Access and full routing table (BGP) for Metro Access. At the moment everything is going fine, but the memory resources are low.  My question is : Is it possible to disable CEF on the switch port that is connected to the ISP ? And in this way the switch doesn't build a switching table with the bgp routes that it receives ? I receive from the ISP about 10k of metro routes and the installed memory on the switch is 64/8 MB.
Thank you in advance.
Calin C.
Level 5
Level 5
If you really want, you can disable CEF on the interface like this:
conf t
int fax/y
no ip route-cache cef
Then you can check if it's disabled:
sw3-c3550#sh ip int fa0/1 | i CEF
  IP CEF switching is disabled
  IP route-cache flags are Fast, No CEF
Here:
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094a83.shtml
You'll find an interesting article about how to  "Achieve Optimal Routing and Reduce BGP Memory  Consumption"
Calin C.
Level 5
Level 5
conf t
int fax/y
Here:
Calin,
You should not disable CEF on the Layer-3-Switch since this will disable hardware-based Layer3-Routing.
To process-switch traffic, the CPU in the 3550 is much too small.
Also, a Cat 3550 does not have sufficient memory to keep a bgp full-table, or two of them.
I would suggest to use at least one or a pair of  2821 router with 1GByte of Ram to do so,
(of course better a pair of 7201 with 2GByte of RAM).
Today, CEF ist working fine in most IOS Versions and many Cisco-uniqe features rely on it.
You may disable soft-config do save memory in BGP.
But iff you have just one upstream, you do not need BGP-full tables but only default-route,
and inject your own prefix. (You do not need bgp or an AS for that with just one connection).
just my 0.01 $,
Juergen.
Juergen, I know that everybody's advice is to use CEF, and this would be the best, if possible. In some cases, you have to deal with the hardware that you have and I just answer to the original question, how and if CEF can be disabled on Cisco 3550.
Cheers,
Calin
