Routing between 2 firewalls on layer 3 switch
kelly-shami
I have two fortigate firewalls on different subnet and I want to do routing between them on a layer 3 switch guide me on how to do that mind you that I still have my switch enabled for routing.
The scenario is like this: the interface connected on the SW like eth1 and eth1 on both firewalls are having trunk and allowing different vlans and after I need to have routing between the two firewalls remember that my switch is enabled to have routing it means it is layer 3 so may I get help for the connectivity with my firewalls like the help me with ideas
8 Replies 8
@kelly-shami hi, if you need to use L3 switch as a routing between 2 firewalls, you can create 2 subnets between FW1 - SW and FW2-SW. then option 1 is using static routing between switches and firewalls or option 2 use dynamic routing protocol like OSPF.
but my concern is , is this real environment use case or testing use case?
if its real use case, share the real requirement here so we can suggest best way to achieve your goal.
Good luck
KB
kelly-shami
Thanks for reaching out
This is a real environment real case where the SW and two firewalls have different subnets FW1 has .5 subnet and FW2 has .3 subnet but when I want to ping the FW 1 from machine is unreachable yet FW 2 is reachable
Option 1 : Static route is the one we need because we don't have any other equipment that can act as a bridge like router for the firewall to do the routing between each other so static routing on layer 3 switch is more easy .
I reviewed different scenarios but neither didn't work
What I need is to help me with how to configure it ?
@kelly-shami hi, thanks. in your PC, what is the gateway IP? is it pointing to the FW1 or 2 (assume your firewalls are not HA)?
since you have a L3 switch in between two firewalls, you can simplify the setup by configuring 3 networks as below
internet ---- FW1 ---subnet1 --\
                                                       SW-----subnet 3 -------- User PC.
Internet ----FW2----subnet 2--/
User PC gateway can configure in L3 switch, and L3 switch can configure to send traffic towards to FW1 and FW2. assume those two firewalls are using for 2 different networks. in this setup L3 switch will be the first routing point for users.
Good luck
KB
kelly-shami
@Kasun Bandara Any help on the above?
But it forti not cisco.
This cisco community and many engineers well known ftd/asa FW not forti
I think you need to re-post it in forti community.
MHM
kelly-shami
@MHM Cisco World Actually the issue is to guide as the previous community member helped and asked me the real environment so he can guide me with how to configure so my issue can be resolved Maybe I may be configuring it wrongly
Ok'
If both FW run HW active/passive then you can config static route toward VIP of FW HA
This make SW forwarding traffic to any FW active in time.
MHM
kelly-shami
@MHM Cisco World Thank you for the answer but I wanted to ask what do you mean by virtual IP pointing to each FW since each FW has it own physical interface on the switch and above the pictures it is how both FW and switch are configured so am trying to understand if I may create new virtual IP under it? Help me out!
