Routing between 2 peers wich changing addressing.
schwermie
We have a cable plant and on remote locations we have some routers running. I want to be flexable so i would like these routers to advertise there connected / static routes to my core. Now the issue. How can i do that? The link to my core uses DHCP, so i don't know what my remote neighbors address will be.
Thanks for the help.
Regards, Marco
Hello Marco,
you could run a routing protocol such as OSPF or EIGRP and redistribute connected routes. Can you post the configuration of your core and one of the hub sites ?
GP
Hi GP,
Thanks for your reply, but the issue is that on an interface DHCP is used, so i don't know what address will be used there.
I believe OSPF and EIGRP doesn't run on interfaces not configured with the network statement. An other issue is that i can't manage to the OSPF running on a MC-16E card with uses MPLS-VPN technology.
I managed to get this issue solved by the following:
router rip
version 2
!disables RIP to customer.
passive-interface FastEthernet0/1
passive-interface Loopback0
!Loads all IP information from all interfaces
network 0.0.0.0
!Filers RIP updates
distribute-list 5 out
no auto-summary
On FE0/0 i force v2 updates and use RIP Authentication.
Marco
