Routing between networks
RJohn
Any help is greatly appreciated!!
Hello
You have duplicate ip addressing between your core switches and router 0
Change router 0 ip addressing to say .254 and make sure the ports on the cores switches connecting to router 0 are trunks
Lastly populate the rip process on the core switchs and router 0 with their respective connected subsets.
Example:
Core sw1
router rip
version 2
network 172.16.0.0
Core sw2
router rip
version 2
network 192.16.50.0
network 192.16.60.0
network 192.16.70.0
network 192.16.80.0
network 192.16.90.0
network 192.16.100.0
no auto-summary
Router 0
interface GigabitEthernet0/0.40
ip address 172.16.40.254 255.255.255.0
interface GigabitEthernet0/1.90
ip address 192.16.90.254 255.255.255.0
router rip
version 2
network 172.16.0.0
network 192.16.90.0
no auto-summary
Kind Regards
Paul
6 Replies 6
Hello
Example:
Core sw1
router rip
version 2
network 172.16.0.0
Core sw2
router rip
version 2
network 192.16.50.0
network 192.16.60.0
network 192.16.70.0
network 192.16.80.0
network 192.16.90.0
no auto-summary
Router 0
router rip
version 2
network 172.16.0.0
network 192.16.90.0
no auto-summary
Kind Regards
Paul
Thank you, I didn't see attachment at first but I have now opened and it seems to be the solution I needed....Thank you!
luis_cordova
Hi @RJohn ,
I reviewed your exercise and found this:
-In CoreSW you must leave the f0/24 interface as a trunk:
-You must also enable a routing protocol on the L3 switches and the router:
-In Router0 you must change the IP entered in the subinterfaces, since this is the same as the VLAN interface of the L3 switches:
With those changes, everything should be ok.
Remember to mark the correct answers as solved, because that helps other users with similar doubts.
Hello
I had already sent you a working PKT file but you have chosen not used it, However I see you have given your router 0 interfaces a .2 and not .254 addressing which isnt a problem however your missing those subnets in the rip process.
Router 0
router rip
version 2
network 172.16.0.0
network 192.16.90.0
no auto-summary
Kind Regards
Paul
Hi @RJohn ,
I attached the exercise with the changes that I mentioned.
So you can review the settings.
