02-18-2015 03:08 AM - edited 03-05-2019 12:49 AM
I have a C887VA-k9 router.
I have interface Fa0 with VLAN 1000 connected to the LAN. It's subnet 192.168.1.0. I can ping the router from a PC from the LAN. The DHCP give an ip coming from the router.
I have interface Fa1 with VLAN 1 (default VLAN) with subnet 192.168.255.10 connected to the internet via a modem with IP 192.168.255.11. I can access the web from the router there is no problem with that.
Or i can't access the web from a PC in the LAN, it seem that there is no routing between the two subnet, VLAN or i did try to enable "ip routing" and it don't take it in the show conf below.
It will be easy without going throught vlan but if i try to put directy an ip address on Interface Fa1 i have "% IP addresses may not be configured on L2 links."
Below all information in details.
Can you help me, why i can't access the web from the PC ?
Thanks a lot
Router#show ip interface brief
Interface IP-Address OK? Method Status Prot ocol
ATM0 unassigned YES NVRAM administratively down down
Ethernet0 unassigned YES NVRAM administratively down down
FastEthernet0 unassigned YES unset up up
FastEthernet1 unassigned YES unset up up
FastEthernet2 unassigned YES unset up down
FastEthernet3 unassigned YES unset down down
Vlan1 192.168.255.10 YES NVRAM up up
Vlan1000 192.168.1.1 YES NVRAM up up
Router#show ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2 E1 - OSPF external type 1, E2 - OSPF external type 2 i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2 ia - IS-IS inter area, * - candidate default, U - per-user static route o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP a - application route + - replicated route, % - next hop override
Gateway of last resort is 192.168.255.11 to network 0.0.0.0
S* 0.0.0.0/0 [1/0] via 192.168.255.11
192.168.1.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.1.0/24 is directly connected, Vlan1000
L 192.168.1.1/32 is directly connected, Vlan1000
192.168.255.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.255.0/24 is directly connected, Vlan1
L 192.168.255.10/32 is directly connected, Vlan1
show conf
version 15.3
hostname Router
boot-start-marker
boot-end-marker
aqm-register-fnf
no aaa new-model
ip dhcp excluded-address 192.168.1.1
ip dhcp pool RESO
network 192.168.1.0 255.255.255.0
dns-server 8.8.8.8
default-router 192.168.1.1
ip cef
no ipv6 cef
license udi pid C887VA-K9 sn FCZ1851C0P0
controller VDSL 0
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface Ethernet0
no ip address
shutdown
interface FastEthernet0
switchport access vlan 1000
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Vlan1
ip address 192.168.255.10 255.255.255.0
interface Vlan1000
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
Solved! Go to Solution.
02-18-2015 03:58 AM
You may need to configure NAT on this router. Who controls the device at 192.168.255.11?
02-18-2015 03:58 AM
02-18-2015 06:08 AM
Thanks, yes apparently the problem was coming from missing NAT !
i have add :
Router(config)#interface vlan 1000
Router(config-if)# nat inside
Router(config-if)# nat outside
Router(config)#access-list 1 permit 192.168.1.0 0.0.0.255
Router(config)#ip nat inside source list 1 interface vlan 1 overload
And i have now the web from the PC.
Thanks a lof for your help
