Routing/BGP Issue
jimmlegs
I have an issue trying to route from my PC at 192.168.150.202 successfully to 62.10.10.66. The 192.168.150/24 and 192.168.68.0/24 networks are connected via cross-connected sites using the 172.30.254.0/29 network to communicate.
62.10.10.66 and 192.168.68.43 are two interfaces on the same server, the private IP has a BGP neighborship with 192.168.68.253 advertising the 62.10.10.66/28 network. This is what my router sees:
B 62.10.10.10 255.255.255.240
[20/1] via 192.168.68.43, 5w1d
A traceroute gets me to the private IP of the correct server but dies there. I do not think that the other router is aware of the path back but I have not been able to figure out how to fix this.
tracert 62.10.10.66
Tracing route to 62.10.10.66 over a maximum of 30 hops
1 4 ms * 3 ms 172.30.254.2
2 3 ms 3 ms 3 ms 192.168.68.43
3 * * * Request timed out.
4 * * * Request timed out.
5 * * * Request timed out.
6 * * * Request timed out.
7 * * * Request timed out.
8 * * * Request timed out.
BGP on the remote side looks like this:
Network Next Hop Metric LocPrf Weight Path
192.168.68.253 0 0 65518 i
* 172.30.0.0 192.168.68.253 0 0 65518 i
* 172.30.254.0/28 192.168.68.253 0 0 65518 i
* 192.168.150.0 192.168.68.253 0 0 65518 i
192.168.68.252 is an L3 switch and the default gateway on the 192.168.68.0/24 network. 192.168.68.253 is the router and gateway of last resort for the L3 switch. I've tried to explicitly add a route for 172.30.254.0/28 over the lan2-if but I get a message saying: "ERROR: Cannot add route, connected route exists"
Any help would be much appreciated.
Relevent Configurations:
interface GigabitEthernet1/2.68
vlan 68
nameif inside-68
security-level 100
ip address 192.168.68.253 255.255.255.0 standby 192.168.68.254
interface GigabitEthernet1/2.254
vlan 254
nameif lan2-if
security-level 100
ip address 172.30.254.4 255.255.255.240
router bgp 65518
bgp log-neighbor-changes
bgp router-id x.x.x.x
address-family ipv4 unicast
neighbor 192.168.68.42 remote-as 15518
neighbor 192.168.68.42 activate
neighbor 192.168.68.43 remote-as 15518
neighbor 192.168.68.43 activate
network 192.168.150.0
network 192.168.152.0
network 192.168.160.0
network 192.168.162.0
network 172.30.254.0 mask 255.255.255.240
auto-summary
synchronization
exit-address-family
route outside 0.0.0.0 0.0.0.0 x.x.x.x 1
route inside-68 62.10.10.66 255.255.255.255 192.168.68.43 1
route lan2-if 192.168.150.0 255.255.255.0 172.30.254.2 1
route lan2-if 192.168.152.0 255.255.255.0 172.30.254.2 1
route lan2-if 192.168.160.0 255.255.255.0 172.30.254.2 1
route lan2-if 192.168.162.0 255.255.255.0 172.30.254.2 1
Jon Marshall
Not sure ICMP will work even with TCP bypass turned on.
As a test can you not add a host route to the L3 switch for 62.10.10.66 pointing to 172.30.254.4 ie.  -
ip route 62.10.10.66 255.255.255.255 172.30.254.4
so the traffic is symmetric both ways.
Jon
26 Replies 26
Jon Marshall
The configuration for your 192.168.68.253 router looks more like a firewall configuration ?
If it is that could cause an issue as your traffic is asymmetric because the ping to the server does not go via that router but direct from the L3 switch as that has an interface in 192.168.68.x but the return traffic points back to that router.
Not really sure what the L3 switch is meant to be doing in the setup.
Jon
Yes, it is an ASA device performing the routing. I believe the switch was supposed to be handling the bulk of the routing however BGP was a requirement from the vendor and the switch does not support it. What are my options to remedy asymmetric routing?
The main issue is the L3 switch ie. if was not doing any routing then the ASA and the router on the top right could simply route traffic between them on the 172.30.24.0/29 subnet and all traffic would be symmetric.
This would also match your description of 172.30.24.0/29 being the subnet that connects your two sites.
But at the moment that description is not strictly accurate because of the L3 switch but it may not be possible to turn off routing as that may effect the rest of your network.
You could just shut down the 192.168.68.x interface on the L3 switch but again you would then need to make sure the routing still worked ie. the L3 switch would then need to know how to reach 192.168.68.x via the ASA firewall.
Jon
Harold Ritter
Hi @jimmlegs ,
It looks like the following routes are learnt via BGP, but none of them is selected as the best path.
 It is probably because the next hop is not reachable. You should do a
show bgp ipv4 uni 192.168.150.0
to get more information.
Here are the results.
BGP routing table entry for 192.168.150.0/24, version 3827 Paths: (1 available, best #1, table default)   Advertised to update-groups:               1   Local     172.30.254.2 from 0 (x.x.x.x)       Origin IGP, metric 0, localpref 100, weight 32768, valid, sourced, local, best
Thank you,
I don't understand why 172.30.254.2 is showing as preferred in the
results but BGP is advertising  the path to "192.168.68.253". Can I force BGP to use the 172.30.254.2 address?
I thought perhaps the routes weren't matching exactly but the statement (in BGP context) "network 192.168.150.0 mask 255.255.255.0" still only shows "network 192.168.150.0" in BGP, I guess the subnet is implied?
Is that
sh ip bgp 192.168.150.0
from the server or the router ?
If the server I would expect the
next hop
to be 192.168.68.253 as that is the BGP peer IP address.
Jon
That is from my ASA. I do not have access to the remote device but from what they had provided me previously they are looking at 192.168.68.253 as the
next-hop
This was what they had provided:
I will request the output for the specific route as you requested previously, apologies that I did not understand the device you were referring to.
Okay, in your original post when you said posted the
sh ip bgp
from the remote side, was that from the server ?
I think I may be confusing the issue because Harold is saying the
 next hop
is not reachable from that output which I have been assuming is from the remote server.
Jon
Yes, "192.168.150.0 192.168.68.253 0 0 65518 i" is from the BGP neighbor
My ASA shows
 I'm going to try
neighbor 192.168.68.42 next-hop-self
as Mr. Ritter advised and will update the thread with the status.
Okay, not sure what 192.168.68.42 is as I thought the neighbor was 192.168.68.43 ?
Also my BGP must be getting rusty because I don't see how that fixes anything ie. the server is seeing the correct
next hop IP
and
next hop
self is usually an IBGP thing but you are peering with EBGP so again not clear how that helps.
That said Harold is way sharper than me so I assume I am just not understanding this fully.
Jon
Hi @Jon Marshall ,
From the config that was provided, I see two neighbors.
Next-hop-seld would need to be applied to both, obviously.
Hi Harold
Sorry but still not following.
The server has the correct
next hop IP
of 192.168.68.253 which is right as far as I can see because it is an EBGP peering with the firewall.
So why do you need
next hop self
ie. what is it achieving as far as the return path from the server is concerned ?
Jon
Hi @jimmlegs ,
In this context, 192.168.68.253 is the neighbor address, not necessarily the
next hop
The
show bgp ipv4 unicast 192.168.150.0
will give you the
next hop address
