04-28-2022 05:09 AM
Hi All,
I have been given a task of creating a IPv4 Scheme table for a network.
I have followed the procedure to create a scheme table however I do not think it looks correct.
I have attached images of the proposed network and my attempt at creating a scheme table.
Could I have some feedback please?
kind regards
04-28-2022 06:32 AM
use online  IP subnet calculator
check each subnet.
04-28-2022 02:25 PM
This looks like VLSM exercise. My approach is based on blocks of IPs or subnets/networks. I would recommend using Magic table and decimal (not binary way) since it is faster and more convenient (no need to convert number to binary values then back to decimal. But, of course use whatever u feel best and works for you.
So, VLSM, I would start with the larger number of hosts; assign block or subnet with /x. then take next avaiable blcok of /x and divide it into next smaller number of hosts , aka /y . keep going down towards smaller one ending on /30.
Yes, I would also recommend test it your work with subnet calculator or in PT assigning IPs to devices
Regards, ML
**Please Rate All Helpful Responses **
