Routing Bit not in the output of IOS image in CML2
In CML2, IOS images do not display
Routing Bit
The output of the command includes
Routing Bit
in
R1#sho ip os database external 150.1.9.9
OSPF Router with ID (150.1.1.1) (Process ID 1)
Type-5 AS External Link States
Routing Bit Set on this LSA in topology Base with MTID 0
LS age: 1786
Options: (No TOS-capability, DC, Upward)
LS Type: AS External Link
Link State ID: 150.1.9.9 (External Network Number )
Advertising Router: 150.1.6.6
LS Seq Number: 80000008
Checksum: 0xC883
Length: 36
Network Mask: /32
Metric Type: 2 (Larger than any link state path)
MTID: 0
Metric: 20
Forward Address: 0.0.0.0
External Route Tag: 0
Compared with another version:
R6#show ip ospf database external
OSPF Router with ID (150.1.6.6) (Process ID 1)
LS age: 1533
Checksum: 0xC883
Length: 36
Network Mask: /32
MTID: 0
Metric: 20
LS age: 1533
Link State ID: 155.1.9.0 (External Network Number )
Checksum: 0xE16E
Length: 36
Network Mask: /24
MTID: 0
Metric: 20
Both destinations are reachable and my only issue is that only one version outputs the
Routing Bit
information.
This problem exists in all versions of IOS code in CML2. I am wondering if anyone is seeing the
Routing Bit
in their CML2 routers and if so, which version of IOS is in use. Any assistance in this matter is greatly appreciated.
CML2 uses the IOSv versions. I noticed the
Routing Bit Set
also not being there in some XE versions. Interesting observation, not sure why that would have been dropped.
Giuseppe Larosa
Hello ksudi@somatelco.com ,
you would like to see the P bit ?   in NSSA area conversion of external type 7 to type 5 requires :
that the NSSA ABR sends the NSSA  O IA type 7 with the P bit set ,
but you are looking at LSA type 5
this is version dependent and means that you are looking at an IOS XE router that implements multitopology , topology Base MTID 0 means the standard IPv4 unicast address family.
Look at RFC
EDit:
https://datatracker.ietf.org/doc/rfc4915/
https://www.rfc-editor.org/rfc/rfc4915.html
yes it is the support of multipology in OSPF   v2
Type   RFC - Proposed Standard (June 2007; No errata)
  Authors   Sina Mirtorabi  , Liem Nguyen  , Abhay Roy  , Peter Psenak  , Padma Pillay-Esnault
  Last updated   2018-12-20
see
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/iproute_ospf/configuration/xe-17/iro-xe-17-book/ip6-route-ospfv3-add-fam-xe.html
This has nothing to do with Cisco Modeling LAbs CML2 as far I know. as @Georg Pauwen has also noted.
Feel free to  provide more info
Hope to help
Giuseppe
Hello Giuseppe,
I am not troubleshooting OSPF at all. I am looking for a vIOS code version that will give me
Routing Bit
Set similar to the output below:
R7#sho ip ospf database router
OSPF Router with ID (150.1.7.7) (Process ID 1)
Router Link States (Area 2)
LS age: 1196
Options: (No TOS-capability, DC)
LS Type: Router Links
Link State ID: 150.1.6.6
LS Seq Number: 80000011
Checksum: 0xE20A
Length: 36
Area Border Router
AS Boundary Router
Unconditional NSSA translator
Number of Links: 1
I have multiple images that are in CML2 and none of them gives the output that includes
Routing Bits
Thanks and hopefully, I clarified my issue.
Routing Bit Set
