Routing for DHCP Superscope
ttuisawau
I am running a DHCP server that has a Superscope: 10.1.A.0 , 10.1.B.0 , 10.1.C.0 and 10.1.D.0 all /24 on a single physical line. The 4 subnets in the superscope are all contiguous.
The physical line terminates on my core router fast ethernet interface.
On my router I have the following configs on the fastethernet inetrface:
interface FastEthernet5/1
description FIBER LINK TO Bldg XXX
ip address 10.1.B.1 255.255.255.0 secondary
ip address 10.1.C.1 255.255.255.0 secondary
ip address 10.1.D.1 255.255.255.0 secondary
ip address 10.1.A.1 255.255.255.0
ip helper-address 10.1.xx.xx
no ip proxy-arp
ip route-cache policy
ip route-cache flow
duplex auto
speed auto
ip route 10.1.A.0 255.255.252.0 FastEthernet5/1
Is the above the correct way to route between the supernet subnetworks on the same physical link?
or do I have to create a subinterface for each subnetwork in the superscope?
I look forward to your help.
Thank you.
kerek
Level 4
Level 4
I would recommend to separate the /24 to different vlans and create subinterfaces on the router.
Krisztian
