routing for servers
suthomas1
Level 6
Level 6
Our core switch is currently hosting all application servers. Remote sites connecting to our head office access these servers via leased lines.
The plan is to add a ASA firewall so that all these servers can be protected.
But, the teams are not willing to physically relocate the server behind the firewall. So the firewall needs to be attached in such a way to the core switch that all
the server bound traffic passes through the firewall rules.
Please suggest ways to achieve this plan.
Thanks in advance.
Scott Fella
You should move your post to the route switch forum. They would be able to help you there.
-Scott
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
Yes it may be possible.  You configure the forwarding such that the server traffic must transit the firewall.  How depends on the equipment.  VRF support can be very useful in these situations.
colinmcallister
Sounds like a use-case for the FWSM if you're running a 6500 core switch..
http://www.cisco.com/en/US/products/hw/modules/ps2706/ps4452/index.html
