Routing in same subnet
adm.mehedi
Dear all,
I am facing some problem, I am using a /29 netmask network. I am using one ip for my office and another one ip for research purpose. But I want to use my research purpose ip in another router, but how it is possible i don't understand. Pls help me all.
My scenario is like that
154.214.32.144/29 = which is given by ISP
Gateway 154.214.32.145
I make two subnet 154.214.32.144/30 & 154.214.32.148/30
For Routing inside my network problem is Isp gateway, and my second subnet gateway.
First Subnet gateway  154.214.32.145 which is isp gateway
Second Subnet Gateway 154.214.32.149
Now need to marge this two. Is it Possible ?
With Regards
Mehedi Hasan
Dan Lukes
Feedback forum is dedicated to other topics. See description for details.
This thread has been moved to more appropriate forum..
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Normally, you cannot have the same network address space in your routing topology more than once.
If you have a bunch of hosts bound to a certain network address space, you might NAT one of your instances, so it appears as a different network address space to the rest of your network.
Or, if the two same network address blocks don't need to intercommunicate, you might be able to have multiple "virtual" networks (using some form of VRF) and have one such network address block in each.
Thank u joseph,
