Routing Issue From host
Today I noticed that we have different paths going to the same site from the same machine.  I think one of them didn’t go pass  GW and FW.
The gateway is 10.25.35.19, so all workstations should use that as the first contact to get out.   Not sure how the trace skipped the GW and FW.
The connection is
Workstation <-> SW <-> Riverbed <-> FW (internet) <-> RTR (MPLS)
CN_HK_RTR1
0/0/0
DMZ
0/0/1
VLAN 1, 30, 31, 32, 33, 34, 37, 38, 250
0/0/2
MPLS
CN_HK_FW1
WAN1
Internet
Port 2
Port 4
CN_HK_RVB (Riverbed)
LAN
WAN
Core SW
Tracing route to www1.epson.com.hk [180.169.121.164] over a maximum of 30 hops:
  1    <1 ms    <1 ms    <1 ms  10.25.35.19
  2    <1 ms    <1 ms    <1 ms  cn_hk_fw1.americas.corp.timex.com [10.25.35.39]
  3     3 ms    10 ms     3 ms  202.155.232.193
  4     3 ms     3 ms     3 ms  175.45.53.217
  5     3 ms     2 ms     2 ms  115.160.187.31
  6     7 ms     3 ms     5 ms  203.131.246.153
  7     5 ms     6 ms     4 ms  ae-13.r03.tkokhk01.hk.bb.gin.ntt.net [129.250.5.37]
  8     5 ms     5 ms     5 ms  ae-1.a01.chwahk02.hk.bb.gin.ntt.net [129.250.5.161]
  9     7 ms    14 ms     6 ms  ae-1.a01.chwahk02.hk.bb.gin.ntt.net [129.250.5.161]
10     6 ms     6 ms     6 ms  xe-0-0-21-2.a01.chwahk02.hk.ce.gin.ntt.net [203.131.241.70]
11    33 ms    33 ms    32 ms  59.43.248.109
12    32 ms     *       33 ms  59.43.246.253
13    35 ms    36 ms    38 ms  59.43.130.205
14    36 ms    37 ms    39 ms  101.95.89.50
15    35 ms    38 ms    38 ms  101.95.40.114
16    33 ms    32 ms    33 ms  101.95.91.162
17     *        *       33 ms  180.166.188.206
18     *        *        *     Request timed out.
Trace complete.
  1    15 ms     2 ms     2 ms  202.155.232.193
  2     3 ms    13 ms     2 ms  202.155.232.193
  3     2 ms     2 ms     2 ms  175.45.53.58
  4     4 ms     3 ms     3 ms  175.45.53.217
  5     2 ms     2 ms     2 ms  115.160.187.31
  6     4 ms     5 ms     3 ms  203.131.246.153
  7     5 ms     5 ms     5 ms  ae-13.r03.tkokhk01.hk.bb.gin.ntt.net [129.250.5.37]
  8     6 ms     6 ms     5 ms  ae-1.a01.chwahk02.hk.bb.gin.ntt.net [129.250.5.161]
  9     6 ms     6 ms     6 ms  xe-0-0-21-2.a01.chwahk02.hk.ce.gin.ntt.net [203.131.241.70]
10    70 ms    32 ms    33 ms  59.43.248.109
11     *        *        *     Request timed out.
12    39 ms    38 ms    38 ms  59.43.130.205
13    40 ms    38 ms    37 ms  ^C
Would anyone be able to help me to see what this may occur?  I have the configurations of the router below just in case.
destination-pattern 774
session target ipv4:192.120.200.90
incoming called-number .
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 77402 voip
description ***Test Calls to ASGCUCM2***
preference 1
session target ipv4:10.25.1.164
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 77403 voip
description ***Test Calls to ASGCUCM1***
preference 3
session target ipv4:10.25.1.163
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 20 pots
destination-pattern 1878...
port 0/1/0:23
forward-digits all
banner motd ^CC
  *    This system and all of its components are restricted to        *
  *    authorized users for legitimate business purposes and are      *
  *    subject to audit.  Persons who violate this policy will        *
  *    be subject to the disciplinary process.  The actual or         *
  *    attempted unauthorized access, use, modification or copying    *
  *    of computer systems is a violation of Federal and State laws.  *
^C
line con 0
logging synchronous
stopbits 1
line aux 0
stopbits 1
line vty 0 4
access-class VTY_ACCESS in vrf-also
transport input ssh
line vty 5 15
transport input ssh
ntp server 10.25.1.123
ntp server 10.25.1.163
end
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
card type t1 0 1
logging buffered 10000000
no logging console
no logging monitor
enable secret 5 $1$uc8W$cbjuo3PsJVfluqUC7032K/
aaa new-model
aaa group server tacacs+ GLSTACACS
server name GLS-TIMEX-01
ip tacacs source-interface GigabitEthernet0/0/1.1
aaa authentication login default group GLSTACACS local
aaa authentication enable default group GLSTACACS enable
aaa authorization console
aaa authorization config-commands
aaa authorization exec default group GLSTACACS local
aaa authorization commands 1 default group GLSTACACS local
aaa authorization commands 2 default group GLSTACACS local
aaa authorization commands 3 default group GLSTACACS local
aaa authorization commands 4 default group GLSTACACS local
aaa authorization commands 5 default group GLSTACACS local
aaa authorization commands 6 default group GLSTACACS local
aaa authorization commands 7 default group GLSTACACS local
aaa authorization commands 8 default group GLSTACACS local
aaa authorization commands 9 default group GLSTACACS local
aaa authorization commands 10 default group GLSTACACS local
aaa authorization commands 11 default group GLSTACACS local
aaa authorization commands 12 default group GLSTACACS local
aaa authorization commands 13 default group GLSTACACS local
aaa authorization commands 14 default group GLSTACACS local
aaa authorization commands 15 default group GLSTACACS local
aaa accounting exec default start-stop group GLSTACACS
aaa accounting commands 1 default start-stop group GLSTACACS
aaa accounting commands 2 default start-stop group GLSTACACS
aaa accounting commands 3 default start-stop group GLSTACACS
aaa accounting commands 4 default start-stop group GLSTACACS
aaa accounting commands 5 default start-stop group GLSTACACS
aaa accounting commands 6 default start-stop group GLSTACACS
aaa accounting commands 7 default start-stop group GLSTACACS
aaa accounting commands 8 default start-stop group GLSTACACS
aaa accounting commands 9 default start-stop group GLSTACACS
aaa accounting commands 10 default start-stop group GLSTACACS
aaa accounting commands 11 default start-stop group GLSTACACS
aaa accounting commands 12 default start-stop group GLSTACACS
aaa accounting commands 13 default start-stop group GLSTACACS
aaa accounting commands 14 default start-stop group GLSTACACS
aaa accounting commands 15 default start-stop group GLSTACACS
aaa session-id common
clock timezone EST -5 0
clock summer-time EDT recurring
ip domain name timex.com
ip name-server 10.25.35.42
ip name-server 10.25.35.46
no ip dhcp use vrf connected
ip dhcp excluded-address 10.25.38.201 10.25.38.254
ip dhcp excluded-address 10.25.36.220 10.25.36.254
ip dhcp excluded-address 10.25.36.200
ip dhcp excluded-address 10.25.36.1 10.25.36.20
ip dhcp excluded-address 10.25.37.201 10.25.37.254
ip dhcp pool Wireless_Scope
network 10.25.37.0 255.255.255.0
default-router 10.25.37.254
dns-server 10.25.35.42 10.25.1.248 10.25.1.248
ip dhcp pool VLAN38_Scope
network 10.25.38.0 255.255.255.0
default-router 10.25.38.254
dns-server 202.130.97.65 202.130.97.66
ip dhcp pool Voice_Scope
network 10.25.36.0 255.255.255.0
default-router 10.25.36.254
dns-server 10.25.1.248
option 150 ip 10.25.1.163 10.25.1.164
ip dhcp pool wireless_scope
subscriber templating
flow exporter TIMEX_NETFLOW
destination 10.25.1.132
source GigabitEthernet0/0/0
transport udp 2055
flow monitor TIMEX_NETFLOW
cache timeout active 60
record netflow-original
isdn switch-type primary-net5
trunk group Outbound
hunt-scheme round-robin
voice call send-alert
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip refer
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711alaw
h323
  call preserve
sip
  registrar server expires max 3600 min 3600
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
codec preference 3 g729br8
codec preference 4 g711alaw
voice class h323 160
  h225 timeout tcp establish 6
voice statistics time-range periodic 60minutes start 00:00 end 00:00 days-of-week daily
voice translation-rule 9
rule 1 /^9\(.*\)/ /\1/
voice translation-profile strip9
translate called 9
voice hpi capture buffer 1000000
voice-card 0/1
dsp services dspfarm
no watchdog
voice-card 0/4
no watchdog
license udi pid ISR4331/K9 sn FDO19390X4A
license accept end user agreement
object-group network o365
host 13.66.58.59
host 13.70.156.206
host 13.71.145.114
host 13.71.145.122
host 13.75.149.223
host 13.71.151.88
host 13.78.120.69
host 13.78.120.70
host 13.78.120.99
host 13.78.122.54
host 13.84.216.209
host 13.84.219.100
host 13.84.222.249
host 13.87.36.128
host 13.88.17.54
host 13.92.181.66
host 13.92.236.241
host 13.93.164.45
13.107.6.156 255.255.255.254
13.107.7.190 255.255.255.254
13.107.9.156 255.255.255.254
host 23.96.32.105
host 23.96.251.50
host 23.96.253.65
host 23.97.66.55
host 23.97.78.94
host 23.99.125.4
host 40.71.88.196
host 40.83.120.174
host 40.83.185.155
host 40.83.185.230
host 40.84.145.72
host 40.112.187.89
host 40.117.96.104
host 40.117.100.187
host 40.117.229.133
host 40.117.229.194
host 51.140.45.81
host 51.140.226.217
host 51.142.213.184
host 52.163.58.153
host 52.163.93.38
host 52.172.49.206
host 52.175.154.183
host 52.175.158.8
host 52.178.27.129
host 52.178.144.25
host 52.178.146.67
host 52.178.150.186
host 52.185.154.106
host 52.187.42.197
host 52.187.78.144
host 52.228.36.141
host 52.231.24.115
host 52.231.204.153
host 52.232.118.68
host 52.232.129.232
host 65.52.144.46
host 65.52.176.186
host 65.52.192.203
host 65.52.240.200
host 65.55.239.168
host 70.37.96.155
host 94.245.88.28
host 94.245.117.53
host 104.40.178.127
host 104.40.179.160
host 104.42.225.143
host 104.42.230.91
host 104.45.225.7
host 104.47.156.62
host 104.211.160.244
host 104.214.144.62
host 104.214.144.252
host 104.214.145.126
host 104.214.145.173
host 104.214.146.199
host 111.221.96.149
host 111.221.104.43
host 137.116.156.3
host 137.116.248.150
host 137.117.17.124
host 138.91.61.107
host 157.55.139.177
157.55.145.0 255.255.255.128
157.55.155.0 255.255.255.128
157.55.227.192 255.255.255.192
host 168.62.104.83
host 168.62.106.224
host 168.63.92.133
host 191.235.95.142
host 191.238.160.173
host 207.46.73.250
host 207.46.141.38
host 207.46.156.124
host 207.46.216.54
host 213.199.128.119
host 13.64.196.27
host 13.64.198.19
host 13.64.198.97
host 13.64.199.41
host 13.76.218.117
host 13.76.219.191
host 13.76.219.210
host 13.91.61.249
host 13.91.98.185
host 13.93.216.68
host 13.93.233.42
host 23.97.61.137
host 23.97.150.21
host 23.97.152.190
host 23.97.209.97
host 23.99.109.44
host 23.99.109.64
host 23.99.116.116
host 23.99.121.207
host 23.100.86.91
host 23.101.14.229
host 23.101.30.126
host 23.102.4.253
host 40.76.1.176
host 40.76.8.142
host 40.76.12.4
host 40.76.12.162
host 40.113.8.255
host 40.113.10.78
host 40.113.11.93
host 40.113.14.159
host 40.117.144.240
host 40.117.151.29
host 40.118.211.172
host 40.121.144.182
host 40.122.168.103
host 65.52.148.27
host 65.52.160.218
host 65.52.184.75
host 65.52.196.64
host 70.37.97.234
host 94.245.108.85
host 104.41.207.73
host 104.42.231.28
host 104.43.140.223
host 104.45.11.195
host 104.46.38.64
host 104.46.50.125
host 104.209.35.177
host 104.215.146.200
host 104.215.198.144
host 111.221.111.196
host 137.116.66.126
host 137.116.81.187
host 157.55.177.39
host 157.55.184.223
host 157.55.80.94
host 168.61.146.25
host 168.61.149.17
host 168.61.170.80
host 168.61.172.71
host 168.62.204.209
host 168.62.29.225
host 168.62.43.8
host 168.63.18.79
host 168.63.29.74
host 168.63.100.61
host 168.63.138.56
host 168.63.172.54
host 168.63.213.238
host 191.237.218.239
host 207.46.134.255
host 207.46.153.155
13.67.50.224 255.255.255.248
13.71.201.64 255.255.255.192
13.106.4.128 255.255.255.128
13.75.48.16 255.255.255.248
13.75.80.16 255.255.255.248
13.106.56.0 255.255.255.128
23.100.16.168 255.255.255.248
23.100.32.136 255.255.255.248
23.100.64.24 255.255.255.248
23.100.72.32 255.255.255.248
23.100.80.64 255.255.255.248
23.100.88.32 255.255.255.248
23.100.101.112 255.255.255.240
23.100.104.16 255.255.255.240
23.100.112.64 255.255.255.248
23.100.120.64 255.255.255.248
23.101.5.104 255.255.255.248
23.101.144.136 255.255.255.248
23.101.165.168 255.255.255.248
23.101.181.128 255.255.255.248
23.101.210.24 255.255.255.248
23.101.222.240 255.255.255.240
23.101.224.16 255.255.255.248
23.101.226.16 255.255.255.240
40.112.64.16 255.255.255.240
40.113.192.16 255.255.255.248
40.114.120.16 255.255.255.248
40.115.152.16 255.255.255.240
40.127.67.24 255.255.255.248
52.125.0.0 255.255.128.0
52.172.144.16 255.255.255.240
65.52.1.16 255.255.255.248
65.52.193.136 255.255.255.248
65.54.170.128 255.255.255.128
70.37.128.0 255.255.254.0
104.40.240.48 255.255.255.240
104.41.13.120 255.255.255.248
104.41.216.16 255.255.255.240
104.42.72.16 255.255.255.248
104.43.208.16 255.255.255.248
104.43.240.16 255.255.255.248
104.44.218.128 255.255.255.128
104.44.254.128 255.255.255.128
104.44.255.0 255.255.255.128
104.45.0.16 255.255.255.240
104.45.208.104 255.255.255.248
104.46.112.8 255.255.255.248
104.46.224.64 255.255.255.240
104.209.144.16 255.255.255.248
104.210.48.8 255.255.255.248
104.210.83.160 255.255.255.248
104.210.208.16 255.255.255.248
104.211.16.16 255.255.255.248
104.211.48.16 255.255.255.248
104.211.88.16 255.255.255.240
host 104.211.98.138
host 104.211.98.146
host 104.211.98.246
host 104.211.99.236
host 104.211.100.160
host 104.211.100.204
host 104.211.102.225
104.211.152.32 255.255.255.224
host 104.211.161.150
host 104.211.161.165
host 104.211.161.185
host 104.211.162.33
host 104.211.165.35
host 104.211.166.139
104.211.216.32 255.255.255.224
host 104.211.224.118
host 104.211.225.135
host 104.211.227.110
host 104.211.231.147
host 104.211.231.248
104.215.96.24 255.255.255.248
104.215.144.64 255.255.255.248
104.215.184.16 255.255.255.248
host 131.253.120.128
132.245.165.0 255.255.255.128
134.170.67.0 255.255.255.128
134.170.172.128 255.255.255.128
157.55.45.128 255.255.255.128
157.55.59.128 255.255.255.128
157.55.130.0 255.255.255.128
157.56.53.128 255.255.255.128
157.56.55.0 255.255.255.128
157.56.58.0 255.255.255.128
157.56.151.0 255.255.255.128
191.232.2.128 255.255.255.128
191.237.248.32 255.255.255.248
191.237.252.192 255.255.255.240
13.107.6.152 255.255.255.254
13.107.9.152 255.255.255.254
13.107.18.10 255.255.255.254
13.107.19.10 255.255.255.254
23.103.160.0 255.255.240.0
23.103.224.0 255.255.224.0
40.96.0.0 255.248.0.0
40.104.0.0 255.254.0.0
157.56.106.128 255.255.255.240
157.56.232.0 255.255.248.0
157.56.240.0 255.255.240.0
191.232.96.0 255.255.224.0
host 191.234.6.152
191.234.140.0 255.255.252.0
191.234.224.0 255.255.252.0
23.103.212.0 255.255.252.0
40.92.0.0 255.252.0.0
40.107.0.0 255.255.128.0
40.107.128.0 255.255.192.0
52.100.0.0 255.252.0.0
65.55.88.0 255.255.255.0
65.55.169.0 255.255.255.0
94.245.120.64 255.255.255.192
216.32.180.0 255.255.254.0
23.103.152.0 255.255.252.0
40.92.128.0 255.255.128.0
40.93.128.0 255.255.128.0
40.94.128.0 255.255.128.0
40.95.128.0 255.255.128.0
52.100.128.0 255.255.128.0
52.101.128.0 255.255.128.0
host 13.67.209.156
host 13.67.214.76
host 13.67.222.144
host 13.67.234.27
host 13.68.31.102
host 13.70.89.162
host 13.70.156.147
host 13.70.159.107
host 13.70.186.54
host 13.73.109.13
host 13.73.155.42
host 13.75.42.168
host 13.75.125.228
host 13.75.127.250
host 13.75.154.195
host 13.75.159.17
host 13.75.159.51
host 13.76.188.52
host 13.76.189.79
host 13.76.241.210
host 13.77.1.253
host 13.77.7.84
host 13.78.59.246
host 13.78.93.8
host 13.78.94.7
host 13.78.95.252
host 13.78.112.190
host 13.79.153.60
host 13.79.161.153
host 13.88.183.247
host 13.88.241.210
host 13.89.44.84
host 13.91.40.251
host 13.91.108.91
host 13.91.252.242
host 13.92.80.132
host 13.92.136.118
host 13.93.149.3
host 13.93.167.93
host 13.93.209.18
host 13.94.47.37
host 13.95.88.228
host 13.95.233.176
host 13.95.234.10
host 13.95.236.192
13.107.3.0 255.255.255.0
13.107.8.0 255.255.255.0
13.107.64.0 255.255.192.0
host 23.97.72.141
host 23.97.78.16
host 23.97.164.28
host 23.99.101.49
host 23.99.101.118
host 23.99.112.73
host 23.99.113.163
host 23.99.115.104
host 23.99.121.38
host 23.99.121.255
host 23.99.122.87
host 23.99.124.9
host 23.99.195.117
host 23.99.213.58
host 23.101.61.176
host 23.101.112.170
host 23.101.115.193
host 23.101.116.26
host 23.101.151.89
host 23.101.156.198
host 23.101.158.111
host 23.102.17.214
host 23.102.24.114
23.103.128.0 255.255.254.0
23.103.130.0 255.255.255.0
23.103.176.128 255.255.255.192
23.103.176.192 255.255.255.224
23.103.178.128 255.255.255.192
23.103.178.192 255.255.255.224
host 40.68.225.164
host 40.68.229.156
host 40.68.230.133
host 40.69.45.108
host 40.74.62.125
host 40.74.84.253
host 40.74.113.62
host 40.74.127.186
host 40.74.128.205
host 40.74.129.215
host 40.74.130.253
host 40.74.143.94
host 40.76.24.32
host 40.76.24.177
host 40.76.77.68
host 40.77.16.36
host 40.78.68.158
host 40.78.71.48
host 40.78.98.202
host 40.78.145.194
host 40.78.146.128
host 40.79.38.101
host 40.79.41.254
host 40.79.74.185
host 40.79.82.21
host 40.83.17.24
host 40.83.176.46
host 40.83.177.162
host 40.83.183.236
host 40.84.28.125
host 40.86.90.132
host 40.86.92.191
host 40.112.188.2
host 40.113.16.205
host 40.113.87.220
host 40.113.136.240
host 40.114.149.220
host 40.114.244.22
host 40.115.1.44
host 40.115.74.171
host 40.117.100.83
host 40.117.145.132
host 40.118.214.164
host 40.118.251.206
host 40.121.200.212
host 40.122.44.96
host 40.122.165.60
host 40.122.168.86
host 40.123.43.195
host 40.123.50.17
host 40.126.239.210
host 40.126.251.57
host 40.127.129.109
host 40.127.169.165
host 51.140.53.252
host 51.140.55.82
host 51.140.183.120
host 51.141.5.99
host 51.141.9.8
host 51.141.12.151
52.112.0.0 255.252.0.0
host 52.160.110.94
host 52.163.224.242
host 52.163.225.1
host 52.163.229.196
host 52.163.230.187
host 52.163.231.50
host 52.163.231.126
host 52.164.255.104
host 52.165.35.53
host 52.165.45.77
host 52.165.150.215
host 52.169.9.241
host 52.169.30.95
host 52.169.104.89
host 52.169.105.194
host 52.169.105.219
host 52.169.106.115
host 52.169.154.144
host 52.169.190.101
host 52.172.53.101
host 52.172.54.196
host 52.172.55.238
host 52.173.190.229
host 52.174.144.192
host 52.174.166.73
host 52.174.166.107
host 52.174.166.156
host 52.174.186.47
host 52.175.24.155
host 52.175.37.105
host 52.175.38.240
host 52.178.34.159
host 52.178.36.12
host 52.178.36.169
host 52.178.38.115
host 52.178.145.227
host 52.178.148.1
host 52.178.148.152
host 52.178.158.225
host 52.178.179.194
host 52.185.146.154
host 52.185.151.102
host 52.187.6.119
host 52.187.79.90
host 52.232.129.71
host 52.232.132.60
host 52.232.135.81
host 52.233.128.227
host 52.233.29.169
host 52.233.30.121
65.55.127.0 255.255.255.0
66.119.157.192 255.255.255.192
66.119.158.0 255.255.255.128
host 104.40.75.8
host 104.40.76.196
host 104.40.91.215
host 104.40.189.177
host 104.41.207.112
host 104.41.208.54
host 104.41.210.140
host 104.42.229.230
host 104.43.12.164
104.44.195.0 255.255.255.0
104.44.200.0 255.255.254.0
host 104.45.18.178
host 104.45.231.95
host 104.46.62.41
host 104.46.96.162
host 104.46.97.194
host 104.46.101.116
host 104.46.105.95
host 104.47.151.128
host 104.208.28.54
host 104.208.31.113
host 104.208.152.137
host 104.209.188.207
host 104.210.1.218
host 104.210.9.95
host 104.210.80.193
host 104.211.162.59
host 104.211.165.113
host 104.211.165.216
111.221.76.128 255.255.255.128
111.221.77.0 255.255.255.192
host 111.221.101.75
111.221.122.192 255.255.255.192
131.253.128.0 255.255.224.0
131.253.160.0 255.255.240.0
132.245.0.0 255.255.255.0
132.245.1.0 255.255.255.128
132.245.112.0 255.255.255.0
132.245.113.0 255.255.255.128
134.170.0.0 255.255.255.128
134.170.54.0 255.255.255.192
134.170.54.128 255.255.255.128
134.170.113.192 255.255.255.192
134.170.115.128 255.255.255.128
host 137.116.66.252
host 137.116.132.4
host 137.116.157.126
host 137.116.159.19
host 137.116.159.228
host 137.116.248.105
host 137.117.109.221
host 137.117.128.25
157.55.40.128 255.255.255.128
157.55.238.0 255.255.255.128
host 157.56.176.68
host 168.61.145.101
host 168.61.152.29
host 168.61.155.249
host 168.63.14.15
host 168.63.204.74
host 168.63.219.57
host 168.63.245.120
host 191.233.80.151
host 191.233.95.169
host 191.234.19.21
host 191.234.20.241
host 191.234.21.145
host 191.234.23.27
host 191.237.44.60
207.46.5.0 255.255.255.0
host 207.46.155.141
host 207.46.156.136
host 207.46.230.50
host 13.107.6.160
host 13.107.9.160
host 23.97.56.236
host 23.97.78.215
host 40.76.80.180
host 40.112.223.206
host 40.127.139.229
host 104.40.214.0
host 104.43.235.252
host 13.67.53.38
host 13.67.56.73
host 13.69.159.30
host 13.75.42.223
host 13.75.47.33
host 13.75.47.241
host 13.107.12.51
host 23.96.208.185
host 23.96.219.115
host 23.97.178.173
host 23.97.218.250
host 23.99.56.164
host 23.99.112.148
host 40.74.50.25
host 40.76.62.115
host 40.78.68.109
host 40.83.178.25
host 40.83.182.229
host 40.84.147.173
host 40.84.149.239
host 40.84.188.180
host 40.84.192.103
host 40.86.88.12
host 40.113.17.180
host 40.113.19.21
host 40.113.22.47
host 40.122.129.128
host 40.124.14.212
host 65.52.210.135
host 104.40.28.30
host 104.40.208.40
host 104.40.218.31
host 104.40.234.17
host 104.209.179.144
host 104.209.212.110
host 104.210.220.25
host 137.116.74.190
host 137.116.77.120
host 168.63.234.40
host 191.236.108.93
host 191.236.157.212
host 207.46.237.84
host 13.73.106.160
host 13.75.158.234
host 13.78.58.132
host 13.79.161.29
host 13.82.54.72
host 13.93.219.105
host 40.74.129.10
host 40.118.97.54
host 51.140.50.132
host 51.141.14.78
host 52.172.158.178
host 52.228.32.190
host 52.231.36.193
host 52.231.202.175
host 52.229.125.229
host 104.41.35.170
host 104.211.163.139
host 13.69.187.20
host 13.70.184.242
host 13.71.155.176
host 13.72.20.247
host 13.72.185.126
host 13.75.153.216
host 13.76.140.48
host 13.78.114.39
host 13.85.84.102
host 13.88.248.161
host 13.88.254.212
host 13.94.209.165
host 13.107.6.171
host 13.107.9.171
host 23.103.183.15
host 40.68.166.51
host 40.74.130.243
host 40.74.138.42
host 40.76.54.124
host 40.86.230.88
host 40.114.192.209
host 40.117.226.146
host 40.126.236.216
host 40.127.79.139
host 51.140.46.128
host 51.141.8.160
host 52.169.109.48
host 52.172.12.123
host 52.172.13.171
host 52.172.152.100
host 52.172.153.104
host 52.175.25.142
host 52.232.128.169
host 104.40.225.204
host 104.41.62.54
host 104.211.103.207
host 104.211.229.230
host 104.214.38.136
host 104.215.194.17
host 134.170.27.86
host 134.170.48.20
host 134.170.48.22
host 134.170.65.86
host 134.170.170.86
host 137.116.172.39
host 137.135.65.72
host 191.235.87.181
host 191.237.40.220
13.107.6.150 255.255.255.254
host 13.107.6.168
13.107.9.150 255.255.255.254
host 13.107.9.168
40.108.0.0 255.255.224.0
40.108.128.0 255.255.128.0
52.104.0.0 255.252.0.0
104.146.0.0 255.255.224.0
104.146.128.0 255.255.128.0
134.170.200.0 255.255.248.0
134.170.208.0 255.255.248.0
191.232.0.0 255.255.254.0
191.234.128.0 255.255.248.0
191.235.0.0 255.255.240.0
host 40.76.22.51
host 40.76.30.255
host 40.76.213.143
host 40.76.216.125
host 40.76.221.181
host 40.76.222.175
host 40.83.185.108
host 40.114.8.214
host 40.114.14.121
host 40.114.15.127
host 40.114.15.142
host 40.114.45.182
host 40.114.40.12
host 40.114.51.204
host 40.114.51.239
host 40.118.210.94
host 40.112.188.120
host 40.118.131.134
host 40.118.135.86
host 40.118.131.27
host 40.118.209.10
host 104.41.155.129
host 104.210.43.160
host 137.135.51.71
host 137.135.52.204
host 138.91.155.70
host 138.91.159.117
host 138.91.160.172
host 138.91.164.243
host 138.91.245.66
username timex privilege 15 password 0 CorpControl
username TimexAccess secret 4 0w25F.R3UEJHpGqijnbkp2kLz29JXwheE9HXdSbh3xA
username glstech privilege 15 secret 5 $1$1ROC$Z08ShqDdnJN3Qkw40nux31
username timexadmin privilege 15 secret 5 $1$DXxr$Kc9prn.o8tG6okWv2nxrr/
redundancy
mode none
controller T1 0/1/0
framing esf
clock source line primary
linecode b8zs
cablelength long 0db
pri-group timeslots 1-24
controller T1 0/1/1
framing esf
clock source line secondary
linecode b8zs
vlan internal allocation policy ascending
class-map match-any gold
match access-group name gold
class-map match-any silver
match access-group name silver
class-map match-all Web-Police
  description class to match HTTP/HTTPS traffic to police
match access-group name Web-Police
policy-map WebPolice
class Web-Police
  police rate 400000 bps
   conform-action transmit
   exceed-action drop
   violate-action drop
class class-default
  fair-queue
policy-map sprint-cos
class gold
  bandwidth percent 45
  set precedence 4
class silver
  bandwidth percent 30
  set precedence 3
interface GigabitEthernet0/0/0
description DMZ network
ip address 192.168.174.16 255.255.255.0
ip flow monitor TIMEX_NETFLOW input
ip flow monitor TIMEX_NETFLOW output
ip policy route-map MPLS_PBR
negotiation auto
description to LAN
no ip address
no ip redirects
no ip proxy-arp
load-interval 30
negotiation auto
description to LAN
encapsulation dot1Q 1 native
ip address 10.25.35.19 255.255.255.0
ip access-group DENY_CHINA_USERS in
ip access-group TEST-CHINA out
no cdp enable
interface GigabitEthernet0/0/1.30
description Registration_30
encapsulation dot1Q 30
ip address 10.30.140.254 255.255.255.0
ip helper-address 172.24.5.1
ip access-group acl_Registration_30 in
no cdp enable
interface GigabitEthernet0/0/1.31
description Remediation_31
encapsulation dot1Q 31
ip address 10.31.140.254 255.255.255.0
ip helper-address 172.24.5.2
no cdp enable
interface GigabitEthernet0/0/1.32
description Dead_End_32
encapsulation dot1Q 32
ip address 10.32.140.254 255.255.255.0
ip helper-address 172.24.5.3
no cdp enable
interface GigabitEthernet0/0/1.33
description Guest_Access_33
encapsulation dot1Q 33
ip address 10.33.140.254 255.255.255.0
ip helper-address 10.25.35.42
ip access-group acl_Guest_Access_33 in
no cdp enable
interface GigabitEthernet0/0/1.34
description boyd_34
encapsulation dot1Q 34
ip address 10.34.140.254 255.255.255.0
ip access-group acl_byod_34 in
no cdp enable
interface GigabitEthernet0/0/1.37
encapsulation dot1Q 37
ip address 10.25.37.254 255.255.255.0
no cdp enable
interface GigabitEthernet0/0/1.38
encapsulation dot1Q 38
ip address 10.25.38.254 255.255.255.0
no cdp enable
interface GigabitEthernet0/0/1.51
description VOICE
encapsulation dot1Q 51
ip address 10.25.36.254 255.255.255.0
no ip redirects
no ip proxy-arp
no cdp enable
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.25.36.254
interface GigabitEthernet0/0/1.250
encapsulation dot1Q 250
ip address 192.168.226.2 255.255.255.248
no ip redirects
no ip proxy-arp
no cdp enable
interface GigabitEthernet0/0/2
ip address 192.168.255.78 255.255.255.252
negotiation auto
interface Service-Engine0/1/0
interface Serial0/1/0:23
no ip address
encapsulation hdlc
isdn incoming-voice voice
interface Serial0/1/1:23
no ip address
encapsulation hdlc
interface Service-Engine0/4/0
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
interface Vlan1
no ip address
router eigrp 1
network 10.25.35.0 0.0.0.255
network 10.25.36.0 0.0.0.255
network 10.25.37.0 0.0.0.255
network 10.25.38.0 0.0.0.255
network 10.30.140.0 0.0.0.255
network 10.31.140.0 0.0.0.255
network 10.32.140.0 0.0.0.255
network 10.33.140.0 0.0.0.255
network 192.168.174.0
redistribute static
router ospf 1
network 10.25.35.0 0.0.0.255 area 0
router bgp 65020
bgp log-neighbor-changes
network 10.10.58.0 mask 255.255.255.0
network 10.25.35.0 mask 255.255.255.0
network 10.25.36.0 mask 255.255.255.0
network 10.25.37.0 mask 255.255.255.0
network 10.25.38.0 mask 255.255.255.0
network 10.30.140.0 mask 255.255.255.0
network 10.31.140.0 mask 255.255.255.0
network 10.32.140.0 mask 255.255.255.0
network 10.33.140.0 mask 255.255.255.0
neighbor 192.168.255.77 remote-as 1803
neighbor 192.168.255.77 version 4
neighbor 192.168.255.77 soft-reconfiguration inbound
ip forward-protocol nd
no ip http server
no ip http secure-server
ip tftp source-interface GigabitEthernet0
ip route 0.0.0.0 0.0.0.0 10.25.35.39
ip route 10.10.58.0 255.255.255.0 192.168.226.1
ip route 10.25.2.159 255.255.255.255 Null0
ip route 172.29.6.0 255.255.255.0 10.25.35.20
ip route 192.168.225.0 255.255.255.240 192.168.226.1
ip ssh rsa keypair-name CN_HK_RTR1.timex.com
ip ssh version 2
ip access-list standard GLSSNMP
permit 10.25.2.34
permit 172.31.255.0 0.0.0.255
permit 12.21.228.240 0.0.0.15
permit 12.21.228.0 0.0.0.255
permit 66.194.25.0 0.0.0.255
ip access-list standard MPLS_PBR
permit 192.168.174.4
permit 192.168.174.11
permit 192.168.174.18
permit 192.168.174.29
permit 192.168.174.36
ip access-list standard MPLS_PRB
ip access-list standard TIMEX-RW
permit 10.25.2.156
permit 10.25.1.156
ip access-list standard TIMEX-SNMP
permit 10.10.58.1
permit 10.10.58.75
permit 10.25.4.159
permit 10.25.1.132
permit 10.25.2.214
permit 10.25.1.245
ip access-list standard VTYACCESS
permit 192.168.255.0 0.0.0.255
permit 66.129.114.48 0.0.0.15
permit 10.0.0.0 0.255.255.255
permit 192.168.0.0 0.0.255.255
permit 193.56.129.0 0.0.0.255
permit 192.137.96.0 0.0.0.255
permit 192.120.200.0 0.0.0.255
permit 192.13.69.0 0.0.0.255
permit 194.49.18.0 0.0.0.255
permit 169.1.1.0 0.0.0.255
ip access-list standard VTY_ACCESS
permit 72.248.107.250
permit 10.25.2.0 0.0.0.255
permit 10.25.4.0 0.0.0.255
permit 10.25.1.0 0.0.0.255
permit 66.194.125.0 0.0.0.255
permit 10.25.35.0 0.0.0.255
ip access-list extended CAP
permit ip host 66.194.25.11 any
permit ip any host 66.194.25.11
ip access-list extended DENY_CHINA_USERS
permit ip host 10.10.58.207 host 10.25.35.57
permit ip 10.10.58.0 0.0.0.255 10.0.0.0 0.255.255.255
permit ip 10.10.58.0 0.0.0.255 172.16.0.0 0.15.255.255
permit ip 10.10.58.0 0.0.0.255 192.168.0.0 0.0.255.255
permit ip 10.10.58.0 0.0.0.63 any
permit ip 10.10.58.64 0.0.0.15 any
permit ip 10.10.58.80 0.0.0.15 64.68.0.0 0.0.255.255
permit ip 10.10.58.96 0.0.0.31 64.68.0.0 0.0.255.255
permit ip 10.10.58.128 0.0.0.127 64.68.0.0 0.0.255.255
permit ip 10.10.58.0 0.0.0.255 object-group o365
deny   ip 10.10.58.0 0.0.0.255 any
permit ip any any
ip access-list extended TEST-CHINA
permit ip any any
ip access-list extended Web-Police
permit tcp any any eq www
permit tcp any any eq 443
deny   ip any any
ip access-list extended acl_Dead_End_32
permit udp 10.32.140.0 0.0.0.255 host 10.25.1.163 eq tftp
permit ip 10.32.140.0 0.0.0.255 host 10.25.1.156
permit udp host 0.0.0.0 eq bootpc host 255.255.255.255 eq bootps
permit udp 10.32.140.0 0.0.0.255 eq bootpc host 10.25.1.156 eq bootps
permit icmp 10.32.140.0 0.0.0.255 host 10.32.140.250 echo
permit icmp 10.32.140.0 0.0.0.255 host 10.32.140.254 echo
permit icmp 10.32.140.0 0.0.0.255 any echo-reply
deny   ip any 10.0.0.0 0.255.255.255
deny   ip any 172.16.0.0 0.15.255.255
deny   ip any 192.168.0.0 0.0.255.255
deny   ip any 0.0.0.0 0.255.255.255
deny   ip any 127.0.0.0 0.255.255.255
deny   ip any 224.0.0.0 31.255.255.255
ip access-list extended acl_Guest_Access_33
permit udp 10.33.140.0 0.0.0.255 host 10.25.1.164 eq tftp
permit ip host 10.33.140.254 host 10.25.35.42
remark ** Allow dhcp to operate
permit udp 10.33.140.0 0.0.0.255 eq bootpc host 10.25.35.42 eq bootps
permit udp 10.33.140.0 0.0.0.255 eq 4567 host 10.25.1.156 eq 4567
permit tcp 10.33.140.0 0.0.0.255 host 10.25.1.156 eq 443
permit tcp 10.33.140.0 0.0.0.255 host 10.25.1.156 eq www
permit udp 10.33.140.0 0.0.0.255 eq 4567 172.24.5.0 0.0.0.255 eq 4567
permit tcp 10.33.140.0 0.0.0.255 172.24.5.0 0.0.0.255 eq 443
permit tcp 10.33.140.0 0.0.0.255 172.24.5.0 0.0.0.255 eq www
permit icmp 10.33.140.0 0.0.0.255 host 10.33.140.1 echo
permit icmp 10.33.140.0 0.0.0.255 any echo-reply
permit udp 10.33.140.0 0.0.0.255 host 10.25.1.163 eq tftp
deny   ip 10.33.140.0 0.0.0.255 10.0.0.0 0.0.0.255
permit ip 10.33.140.0 0.0.0.255 any
ip access-list extended acl_Registration_30
permit udp 10.30.140.0 0.0.0.255 host 10.25.1.163 eq tftp
permit ip 10.30.140.0 0.0.0.255 host 10.25.35.42
permit ip 10.30.140.0 0.0.0.255 host 10.25.35.46
permit ip 10.30.140.0 0.0.0.255 10.30.140.0 0.0.0.255
permit ip 10.30.140.0 0.0.0.255 host 10.25.1.156
permit ip 10.30.140.0 0.0.0.255 host 172.24.5.1
permit ip host 10.30.140.254 host 10.25.35.42
permit udp 10.30.140.0 0.0.0.255 eq bootpc host 10.25.1.156 eq bootps
permit udp 10.30.140.0 0.0.0.255 eq bootpc host 172.24.5.1 eq bootps
permit udp 10.30.140.0 0.0.0.255 eq 4567 host 10.25.1.156 eq 4567
permit tcp 10.30.140.0 0.0.0.255 host 10.25.1.156 eq 443
permit tcp 10.30.140.0 0.0.0.255 host 10.25.1.156 eq www
permit udp 10.30.140.0 0.0.0.255 eq 4567 172.24.5.0 0.0.0.255 eq 4567
permit tcp 10.30.140.0 0.0.0.255 172.24.5.0 0.0.0.255 eq 443
permit tcp 10.30.140.0 0.0.0.255 172.24.5.0 0.0.0.255 eq www
permit icmp 10.30.140.0 0.0.0.255 host 10.30.140.1 echo
permit ip host 10.34.140.250 host 10.25.35.42
permit udp 10.34.140.0 0.0.0.255 eq bootpc host 10.25.35.42 eq bootps
permit ip host 10.25.35.81 host 10.25.2.210
permit tcp any 192.137.96.0 0.0.0.255 eq smtp 443 3389 389
permit icmp 10.30.140.0 0.0.0.255 any echo-reply
deny   ip 10.30.140.0 0.0.0.255 10.25.0.0 0.0.255.255
permit ip 10.30.140.0 0.0.0.255 any
ip access-list extended acl_Remediation_31
permit ip 10.31.140.0 0.0.0.255 host 10.25.1.156
permit udp 10.31.140.0 0.0.0.255 eq bootpc host 10.25.1.156 eq bootps
permit udp 10.31.140.0 0.0.0.255 host 10.25.1.163 eq tftp
permit icmp 10.31.140.0 0.0.0.255 host 10.31.140.250 echo
permit icmp 10.31.140.0 0.0.0.255 host 10.31.140.254 echo
permit icmp 10.31.140.0 0.0.0.255 any echo-reply
deny   udp any any eq domain
deny   tcp any any eq domain
permit ip 10.31.140.0 0.0.0.255 any
ip access-list extended acl_byod_34
permit udp 10.34.140.0 0.0.0.255 host 10.25.1.163 eq tftp
permit udp 10.34.140.0 0.0.0.255 host 10.25.1.164 eq tftp
permit ip 10.34.140.0 0.0.0.255 host 10.25.1.156
permit ip 10.34.140.0 0.0.0.255 host 172.24.5.1
permit ip 10.34.140.0 0.0.0.255 host 172.24.5.4
permit udp 10.34.140.0 0.0.0.255 eq 4567 host 10.25.1.156 eq 4567
permit tcp 10.34.140.0 0.0.0.255 host 10.25.1.156 eq 443
permit tcp 10.34.140.0 0.0.0.255 host 10.25.1.156 eq www
permit udp 10.34.140.0 0.0.0.255 eq 4567 172.24.5.0 0.0.0.255 eq 4567
permit tcp 10.34.140.0 0.0.0.255 172.24.5.0 0.0.0.255 eq 443
permit tcp 10.34.140.0 0.0.0.255 172.24.5.0 0.0.0.255 eq www
permit icmp 10.34.140.0 0.0.0.255 host 10.34.140.1 echo
permit icmp 10.34.140.0 0.0.0.255 any echo-reply
deny   ip 10.34.140.0 0.0.0.255 10.0.0.0 0.255.255.255
ip access-list extended exit
ip access-list extended gold
permit tcp any any precedence flash-override
permit ip host 192.168.255.30 172.31.255.0 0.0.0.255
permit tcp 10.25.35.0 0.0.0.255 any eq www 3389
permit tcp 10.10.58.0 0.0.0.255 any eq www 3389
permit ip host 10.25.35.81 host 192.13.69.170
permit ip host 10.25.35.81 host 192.120.203.100
permit tcp any host 10.25.2.210 eq 3389
permit tcp any host 192.120.203.100 eq 1521 7779 7780 7778 1950
ip access-list extended silver
permit tcp any 10.25.0.0 0.0.255.255 eq smtp 443 3389 389
permit tcp any 10.1.250.0 0.0.0.255 eq smtp 443 3389 389
permit tcp any 10.7.0.0 0.0.255.255 eq smtp 443 3389 389
permit tcp any 192.168.0.0 0.0.255.255 eq smtp 443 3389 389
permit tcp any 10.2.0.0 0.0.15.255 eq smtp 443 3389 389
permit tcp any 169.1.1.0 0.0.0.255 eq smtp 443 3389 389
permit tcp any 193.56.129.0 0.0.0.255 eq smtp 443 3389 389
permit tcp any 192.120.0.0 0.0.255.255 eq smtp 443 3389 389
permit tcp any host 10.1.250.106 eq 7779 7780
ip access-list extended tac
permit icmp host 10.30.140.250 host 10.30.140.254
permit ip any any
logging host 10.25.2.32
route-map MPLS_PBR permit 10
match ip address MPLS_PBR
set ip next-hop 192.168.255.77
route-map MPLS_PBR permit 20
snmp-server community 26BoUeF7BU RW TIMEX-RW
snmp-server community TIMEX_RO RO TIMEX-SNMP
snmp-server community Timex_RO RO TIMEX-SNMP
snmp-server community glsiiabdfi RO GLSSNMP
snmp-server trap link ietf
snmp-server trap-source GigabitEthernet0/0/1.1
snmp-server source-interface informs GigabitEthernet0/0/1.1
snmp-server enable traps snmp linkdown linkup coldstart warmstart
snmp-server host 10.25.1.156 26BoUeF7BU
snmp-server host 10.25.2.156 26BoUeF7BU
snmp ifmib ifindex persist
control-plane
voice-port 0/1/0:23
voice-port 0/1/1:23
mgcp
mgcp call-agent 10.25.1.163 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 ecm
mgcp fax t38 inhibit
no mgcp explicit hookstate
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface GigabitEthernet0/0/1.51
mgcp bind media source-interface GigabitEthernet0/0/1.51
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
sccp local GigabitEthernet0/0/1.51
sccp ccm 10.25.1.163 identifier 1 version 7.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 2 register MTPd48cb5b38b62
associate profile 1 register TRNd48cb5b38b62
associate profile 3 register CFBd48cb5b38b62
keepalive retries 5
switchover method immediate
switchback method immediate
switchback interval 15
signaling dscp af31
ccm-manager music-on-hold
ccm-manager fallback-mgcp
ccm-manager redundant-host 10.25.1.164
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager config server 10.25.1.163
ccm-manager config
dspfarm profile 1 transcode
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
maximum sessions 3
associate application SCCP
dspfarm profile 3 conference
codec g729br8
codec g729r8
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
maximum sessions 2
dspfarm profile 2 mtp
codec g711ulaw
maximum sessions software 250
dial-peer voice 1002 voip
description User Extenstions
preference 1
destination-pattern 3..
progress_ind setup enable 1
modem passthrough nse codec g711ulaw
voice-class codec 1
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 1003 voip
preference 1
destination-pattern 7..
voice-class codec 1
no vad
dial-peer voice 1001 voip
preference 1
destination-pattern 0..
voice-class codec 1
no vad
dial-peer voice 9 pots
description Outbound
translation-profile outgoing strip9
preference 1
destination-pattern 9T
progress_ind progress enable 8
translate-outgoing called 9
port 0/1/0:23
forward-digits all
dial-peer voice 99 voip
description outbound VOIP
translation-profile incoming strip-9
incoming called-number 9T
codec g711ulaw
no vad
dial-peer voice 11 pots
preference 1
destination-pattern 9[2-7].......
port 0/1/0:23
forward-digits 8
dial-peer voice 13 pots
preference 1
destination-pattern 91850.
port 0/1/0:23
forward-digits 5
dial-peer voice 14 pots
preference 1
destination-pattern 91083
port 0/1/0:23
forward-digits 4
dial-peer voice 16 pots
preference 1
destination-pattern 9109
port 0/1/0:23
forward-digits 3
dial-peer voice 10 pots
preference 2
port 0/1/1:23
forward-digits all
dial-peer voice 12 pots
preference 2
port 0/1/1:23
forward-digits 8
dial-peer voice 18 pots
preference 2
port 0/1/0:23
forward-digits 5
dial-peer voice 15 pots
preference 1
port 0/1/1:23
forward-digits 4
dial-peer voice 17 pots
preference 2
port 0/1/1:23
forward-digits 3
dial-peer voice 72701 voip
description ***Test Calls to PPHCBCM1***
preference 1
destination-pattern 727
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 72702 voip
preference 2
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 72703 voip
preference 3
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 77401 voip
preference 2
dtmf-relay rtp-nte
codec g711ulaw
preference 1
dtmf-relay rtp-nte
codec g711ulaw
preference 3
dtmf-relay rtp-nte
codec g711ulaw
port 0/1/0:23
forward-digits all
banner motd ^CC
^C
line con 0
logging synchronous
stopbits 1
line aux 0
stopbits 1
line vty 0 4
transport input ssh
line vty 5 15
transport input ssh
end
CN_HK_RTR1#
CN_HK_RTR1#sho ip rou
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       a - application route
       + - replicated route, % - next hop override, p - overrides from PfR
Gateway of last resort is 10.25.35.39 to network 0.0.0.0
S*    0.0.0.0/0 [1/0] via 10.25.35.39
      10.0.0.0/8 is variably subnetted, 113 subnets, 4 masks
B        10.1.4.0/24 [20/0] via 192.168.255.77, 7w0d
B        10.1.220.0/24 [20/0] via 192.168.255.77, 1w2d
B        10.1.250.0/24 [20/0] via 192.168.255.77, 7w0d
B        10.5.1.0/24 [20/0] via 192.168.255.77, 7w0d
B        10.7.0.0/16 [20/0] via 192.168.255.77, 1w5d
B        10.8.4.0/30 [20/0] via 192.168.255.77, 7w0d
B        10.8.10.0/30 [20/0] via 192.168.255.77, 3d05h
B        10.8.10.4/30 [20/0] via 192.168.255.77, 2d17h
B        10.8.10.20/30 [20/0] via 192.168.255.77, 1w0d
B        10.8.10.24/30 [20/0] via 192.168.255.77, 7w0d
B        10.8.10.32/30 [20/0] via 192.168.255.77, 1w5d
B        10.8.10.100/30 [20/0] via 192.168.255.77, 1w1d
B        10.9.10.0/24 [20/0] via 192.168.255.77, 7w0d
S        10.10.58.0/24 [1/0] via 192.168.226.1
B        10.25.1.0/24 [20/0] via 192.168.255.77, 1w2d
B        10.25.2.0/24 [20/0] via 192.168.255.77, 7w0d
B        10.25.2.143/32 [20/0] via 192.168.255.77, 7w0d
S        10.25.2.159/32 is directly connected, Null0
B        10.25.2.228/32 [20/0] via 192.168.255.77, 7w0d
B        10.25.3.0/24 [20/0] via 192.168.255.77, 7w0d
B        10.25.4.0/24 [20/0] via 192.168.255.77, 7w0d
B        10.25.5.0/24 [20/0] via 192.168.255.77, 7w0d
B        10.25.6.0/24 [20/0] via 192.168.255.77, 7w0d
B        10.25.7.0/24 [20/0] via 192.168.255.77, 7w0d
B        10.25.8.0/24 [20/0] via 192.168.255.77, 7w0d
B        10.25.11.0/24 [20/0] via 192.168.255.77, 7w0d
B        10.25.14.0/24 [20/0] via 192.168.255.77, 00:01:04
B        10.25.16.0/24 [20/0] via 192.168.255.77, 7w0d
B        10.25.17.0/24 [20/0] via 192.168.255.77, 18:27:35
B        10.25.20.0/24 [20/0] via 192.168.255.77, 7w0d
B        10.25.25.0/24 [20/0] via 192.168.255.77, 7w0d
B        10.25.30.0/24 [20/0] via 192.168.255.77, 3w5d
C        10.25.35.0/24 is directly connected, GigabitEthernet0/0/1.1
L        10.25.35.19/32 is directly connected, GigabitEthernet0/0/1.1
C        10.25.36.0/24 is directly connected, GigabitEthernet0/0/1.51
L        10.25.36.254/32 is directly connected, GigabitEthernet0/0/1.51
C        10.25.37.0/24 is directly connected, GigabitEthernet0/0/1.37
L        10.25.37.254/32 is directly connected, GigabitEthernet0/0/1.37
C        10.25.38.0/24 is directly connected, GigabitEthernet0/0/1.38
L        10.25.38.254/32 is directly connected, GigabitEthernet0/0/1.38
B        10.25.40.0/24 [20/0] via 192.168.255.77, 7w0d
B        10.25.41.0/24 [20/0] via 192.168.255.77, 7w0d
B        10.25.45.0/24 [20/0] via 192.168.255.77, 1w3d
B        10.25.46.0/24 [20/0] via 192.168.255.77, 1w3d
B        10.25.48.0/24 [20/0] via 192.168.255.77, 7w0d
B        10.25.60.0/24 [20/0] via 192.168.255.77, 1w0d
B        10.25.70.0/24 [20/0] via 192.168.255.77, 7w0d
B        10.25.71.0/24 [20/0] via 192.168.255.77, 7w0d
B        10.25.82.0/24 [20/0] via 192.168.255.77, 1w1d
B        10.25.83.0/24 [20/0] via 192.168.255.77, 1w1d
B        10.25.84.0/24 [20/0] via 192.168.255.77, 1w1d
B        10.25.88.0/24 [20/0] via 192.168.255.77, 1w1d
B        10.25.90.0/24 [20/0] via 192.168.255.77, 1w1d
B        10.25.94.0/24 [20/0] via 192.168.255.77, 1w1d
B        10.25.95.0/24 [20/0] via 192.168.255.77, 1w1d
B        10.25.96.0/24 [20/0] via 192.168.255.77, 1w1d
B        10.25.97.0/24 [20/0] via 192.168.255.77, 1w1d
B        10.25.131.0/24 [20/0] via 192.168.255.77, 7w0d
B        10.30.7.0/24 [20/0] via 192.168.255.77, 7w0d
B        10.30.8.0/24 [20/0] via 192.168.255.77, 7w0d
B        10.30.17.0/24 [20/0] via 192.168.255.77, 18:27:37
B        10.30.20.0/24 [20/0] via 192.168.255.77, 7w0d
B        10.30.30.0/24 [20/0] via 192.168.255.77, 3w5d
B        10.30.44.0/24 [20/0] via 192.168.255.77, 1w3d
B        10.30.49.0/24 [20/0] via 192.168.255.77, 7w0d
B        10.30.65.0/24 [20/0] via 192.168.255.77, 7w0d
B        10.30.95.0/24 [20/0] via 192.168.255.77, 1w1d
B        10.30.120.0/24 [20/0] via 192.168.255.77, 3d05h
C        10.30.140.0/24 is directly connected, GigabitEthernet0/0/1.30
L        10.30.140.254/32 is directly connected, GigabitEthernet0/0/1.30
B        10.31.7.0/24 [20/0] via 192.168.255.77, 7w0d
B        10.31.8.0/24 [20/0] via 192.168.255.77, 7w0d
B        10.31.15.0/24 [20/0] via 192.168.255.77, 00:32:09
B        10.31.17.0/24 [20/0] via 192.168.255.77, 18:27:37
B        10.31.30.0/24 [20/0] via 192.168.255.77, 3w5d
B        10.31.44.0/24 [20/0] via 192.168.255.77, 1w3d
B        10.31.49.0/24 [20/0] via 192.168.255.77, 7w0d
B        10.31.65.0/24 [20/0] via 192.168.255.77, 7w0d
B        10.31.95.0/24 [20/0] via 192.168.255.77, 1w1d
B        10.31.120.0/24 [20/0] via 192.168.255.77, 3d05h
C        10.31.140.0/24 is directly connected, GigabitEthernet0/0/1.31
L        10.31.140.254/32 is directly connected, GigabitEthernet0/0/1.31
B        10.32.7.0/24 [20/0] via 192.168.255.77, 7w0d
B        10.32.8.0/24 [20/0] via 192.168.255.77, 7w0d
B        10.32.15.0/24 [20/0] via 192.168.255.77, 00:32:09
B        10.32.17.0/24 [20/0] via 192.168.255.77, 18:27:37
B        10.32.30.0/24 [20/0] via 192.168.255.77, 3w5d
B        10.32.49.0/24 [20/0] via 192.168.255.77, 7w0d
B        10.32.60.0/24 [20/0] via 192.168.255.77, 1w0d
B        10.32.65.0/24 [20/0] via 192.168.255.77, 7w0d
B        10.32.95.0/24 [20/0] via 192.168.255.77, 1w1d
B        10.32.120.0/24 [20/0] via 192.168.255.77, 3d05h
C        10.32.140.0/24 is directly connected, GigabitEthernet0/0/1.32
L        10.32.140.254/32 is directly connected, GigabitEthernet0/0/1.32
B        10.33.7.0/24 [20/0] via 192.168.255.77, 7w0d
B        10.33.8.0/24 [20/0] via 192.168.255.77, 7w0d
B        10.33.15.0/24 [20/0] via 192.168.255.77, 00:32:09
B        10.33.17.0/24 [20/0] via 192.168.255.77, 18:27:37
B        10.33.20.0/24 [20/0] via 192.168.255.77, 7w0d
B        10.33.30.0/24 [20/0] via 192.168.255.77, 3w5d
B        10.33.44.0/24 [20/0] via 192.168.255.77, 1w3d
B        10.33.49.0/24 [20/0] via 192.168.255.77, 7w0d
B        10.33.60.0/24 [20/0] via 192.168.255.77, 1w0d
B        10.33.65.0/24 [20/0] via 192.168.255.77, 7w0d
B        10.33.95.0/24 [20/0] via 192.168.255.77, 1w1d
B        10.33.120.0/24 [20/0] via 192.168.255.77, 3d05h
C        10.33.140.0/24 is directly connected, GigabitEthernet0/0/1.33
L        10.33.140.254/32 is directly connected, GigabitEthernet0/0/1.33
B        10.34.60.0/24 [20/0] via 192.168.255.77, 1w0d
B        10.34.120.0/24 [20/0] via 192.168.255.77, 3d05h
C        10.34.140.0/24 is directly connected, GigabitEthernet0/0/1.34
L        10.34.140.254/32 is directly connected, GigabitEthernet0/0/1.34
B        10.35.120.0/24 [20/0] via 192.168.255.77, 3d05h
      12.0.0.0/28 is subnetted, 1 subnets
B        12.21.228.240 [20/0] via 192.168.255.77, 4d23h
      57.0.0.0/32 is subnetted, 1 subnets
B        57.66.105.11 [20/0] via 192.168.255.77, 7w0d
      63.0.0.0/32 is subnetted, 2 subnets
B        63.167.94.79 [20/0] via 192.168.255.77, 7w0d
B        63.169.129.148 [20/0] via 192.168.255.77, 7w0d
      68.0.0.0/30 is subnetted, 1 subnets
B        68.136.43.224 [20/0] via 192.168.255.77, 1w5d
      72.0.0.0/30 is subnetted, 1 subnets
B        72.139.35.208 [20/0] via 192.168.255.77, 7w0d
      82.0.0.0/32 is subnetted, 1 subnets
B        82.195.189.30 [20/0] via 192.168.255.77, 7w0d
      89.0.0.0/8 is variably subnetted, 3 subnets, 2 masks
B        89.191.220.205/32 [20/0] via 192.168.255.77, 7w0d
B        89.191.220.208/30 [20/0] via 192.168.255.77, 7w0d
B        89.191.223.132/30 [20/0] via 192.168.255.77, 7w0d
      144.223.0.0/32 is subnetted, 2 subnets
B        144.223.25.42 [20/0] via 192.168.255.77, 7w0d
B        144.223.144.38 [20/0] via 192.168.255.77, 7w0d
      152.185.0.0/30 is subnetted, 2 subnets
B        152.185.243.188 [20/0] via 192.168.255.77, 1w5d
B        152.185.247.160 [20/0] via 192.168.255.77, 1w5d
      172.20.0.0/24 is subnetted, 1 subnets
B        172.20.1.0 [20/0] via 192.168.255.77, 7w0d
      172.24.0.0/24 is subnetted, 2 subnets
B        172.24.5.0 [20/0] via 192.168.255.77, 1w2d
B        172.24.6.0 [20/0] via 192.168.255.77, 7w0d
      172.28.0.0/24 is subnetted, 1 subnets
D        172.28.2.0 [90/3072] via 10.30.140.250, 7w0d, GigabitEthernet0/0/1.30
                    [90/3072] via 10.25.35.252, 7w0d, GigabitEthernet0/0/1.1
      172.29.0.0/24 is subnetted, 4 subnets
S        172.29.6.0 [1/0] via 10.25.35.20
B        172.29.7.0 [20/0] via 192.168.255.77, 7w0d
B        172.29.11.0 [20/0] via 192.168.255.77, 7w0d
B        172.29.12.0 [20/0] via 192.168.255.77, 3d05h
B     172.30.0.0/16 [20/0] via 192.168.255.77, 7w0d
      172.31.0.0/30 is subnetted, 2 subnets
B        172.31.255.232 [20/0] via 192.168.255.77, 1w5d
B        172.31.255.248 [20/0] via 192.168.255.77, 7w0d
B     192.55.12.0/24 [20/0] via 192.168.255.77, 18:27:37
B     192.120.200.0/24 [20/0] via 192.168.255.77, 3d05h
B     192.120.201.0/24 [20/0] via 192.168.255.77, 3d05h
B     192.120.202.0/24 [20/0] via 192.168.255.77, 3d05h
B     192.120.203.0/24 [20/0] via 192.168.255.77, 3d05h
B     192.120.204.0/24 [20/0] via 192.168.255.77, 3d05h
B     192.120.205.0/24 [20/0] via 192.168.255.77, 3d05h
B     192.120.206.0/24 [20/0] via 192.168.255.77, 3d05h
B     192.120.207.0/24 [20/0] via 192.168.255.77, 3d05h
B     192.120.208.0/24 [20/0] via 192.168.255.77, 3d05h
B     192.120.209.0/24 [20/0] via 192.168.255.77, 3d05h
B     192.120.210.0/24 [20/0] via 192.168.255.77, 3d05h
B     192.120.211.0/24 [20/0] via 192.168.255.77, 3d05h
B     192.137.94.0/24 [20/0] via 192.168.255.77, 7w0d
B     192.137.96.0/24 [20/0] via 192.168.255.77, 7w0d
B     192.168.172.0/24 [20/0] via 192.168.255.77, 7w0d
      192.168.174.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.174.0/24 is directly connected, GigabitEthernet0/0/0
L        192.168.174.16/32 is directly connected, GigabitEthernet0/0/0
B     192.168.200.0/24 [20/0] via 192.168.255.77, 7w0d
      192.168.225.0/28 is subnetted, 1 subnets
S        192.168.225.0 [1/0] via 192.168.226.1
      192.168.226.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.226.0/29 is directly connected, GigabitEthernet0/0/1.250
L        192.168.226.2/32 is directly connected, GigabitEthernet0/0/1.250
B     192.168.246.0/24 [20/0] via 192.168.255.77, 1w1d
B     192.168.248.0/24 [20/0] via 192.168.255.77, 1w1d
      192.168.254.0/24 is variably subnetted, 11 subnets, 2 masks
B        192.168.254.0/24 [20/0] via 192.168.255.77, 7w0d
B        192.168.254.0/30 [20/0] via 192.168.255.77, 7w0d
B        192.168.254.4/30 [20/0] via 192.168.255.77, 7w0d
B        192.168.254.8/30 [20/0] via 192.168.255.77, 7w0d
B        192.168.254.12/30 [20/0] via 192.168.255.77, 7w0d
B        192.168.254.16/30 [20/0] via 192.168.255.77, 7w0d
B        192.168.254.20/30 [20/0] via 192.168.255.77, 1d13h
B        192.168.254.24/30 [20/0] via 192.168.255.77, 7w0d
B        192.168.254.28/30 [20/0] via 192.168.255.77, 7w0d
B        192.168.254.60/30 [20/0] via 192.168.255.77, 7w0d
B        192.168.254.64/30 [20/0] via 192.168.255.77, 7w0d
      192.168.255.0/24 is variably subnetted, 18 subnets, 2 masks
B        192.168.255.0/30 [20/0] via 192.168.255.77, 7w0d
B        192.168.255.8/30 [20/0] via 192.168.255.77, 7w0d
B        192.168.255.20/30 [20/0] via 192.168.255.77, 7w0d
B        192.168.255.32/30 [20/0] via 192.168.255.77, 3d05h
B        192.168.255.40/30 [20/0] via 192.168.255.77, 7w0d
B        192.168.255.44/30 [20/0] via 192.168.255.77, 7w0d
B        192.168.255.60/30 [20/0] via 192.168.255.77, 7w0d
B        192.168.255.69/32 [20/0] via 192.168.255.77, 1w2d
B        192.168.255.72/30 [20/0] via 192.168.255.77, 1w5d
C        192.168.255.76/30 is directly connected, GigabitEthernet0/0/2
L        192.168.255.78/32 is directly connected, GigabitEthernet0/0/2
B        192.168.255.84/30 [20/0] via 192.168.255.77, 7w0d
B        192.168.255.88/30 [20/0] via 192.168.255.77, 3d20h
B        192.168.255.92/30 [20/0] via 192.168.255.77, 7w0d
B        192.168.255.96/30 [20/0] via 192.168.255.77, 5w6d
B        192.168.255.100/30 [20/0] via 192.168.255.77, 7w0d
B        192.168.255.104/30 [20/0] via 192.168.255.77, 7w0d
B        192.168.255.108/30 [20/0] via 192.168.255.77, 3w3d
B     192.169.100.0/24 [20/0] via 192.168.255.77, 7w0d
B     192.169.101.0/24 [20/0] via 192.168.255.77, 7w0d
B     192.169.102.0/24 [20/0] via 192.168.255.77, 1w5d
B     192.169.104.0/22 [20/0] via 192.168.255.77, 7w0d
B     193.56.129.0/24 [20/0] via 192.168.255.77, 1w3d
B     194.49.18.0/24 [20/0] via 192.168.255.77, 7w0d
      198.178.131.0/32 is subnetted, 1 subnets
B        198.178.131.1 [20/0] via 192.168.255.77, 7w0d
      199.3.247.0/28 is subnetted, 1 subnets
B        199.3.247.144 [20/0] via 192.168.255.77, 7w0d
      203.98.194.0/32 is subnetted, 1 subnets
B        203.98.194.127 [20/0] via 192.168.255.77, 7w0d
      203.98.202.0/24 is variably subnetted, 5 subnets, 2 masks
B        203.98.202.40/30 [20/0] via 192.168.255.77, 7w0d
B        203.98.202.44/30 [20/0] via 192.168.255.77, 7w0d
B        203.98.202.48/30 [20/0] via 192.168.255.77, 7w0d
B        203.98.202.52/32 [20/0] via 192.168.255.77, 7w0d
B        203.98.202.56/30 [20/0] via 192.168.255.77, 7w0d
      203.222.37.0/32 is subnetted, 1 subnets
B        203.222.37.42 [20/0] via 192.168.255.77, 1d13h
      203.222.39.0/32 is subnetted, 1 subnets
B        203.222.39.78 [20/0] via 192.168.255.77, 7w0d
      203.222.43.0/28 is subnetted, 1 subnets
B        203.222.43.112 [20/0] via 192.168.255.77, 7w0d
      203.222.191.0/28 is subnetted, 1 subnets
B        203.222.191.192 [20/0] via 192.168.255.77, 7w0d
      206.114.70.0/30 is subnetted, 1 subnets
B        206.114.70.232 [20/0] via 192.168.255.77, 1w5d
      208.20.7.0/28 is subnetted, 1 subnets
B        208.20.7.16 [20/0] via 192.168.255.77, 7w0d
      208.21.31.0/32 is subnetted, 1 subnets
B        208.21.31.90 [20/0] via 192.168.255.77, 7w0d
      217.147.97.0/32 is subnetted, 1 subnets
B        217.147.97.154 [20/0] via 192.168.255.77, 7w0d
      217.151.241.0/30 is subnetted, 1 subnets
B        217.151.241.148 [20/0] via 192.168.255.77, 7w0d
      217.151.242.0/24 is variably subnetted, 2 subnets, 2 masks
B        217.151.242.135/32 [20/0] via 192.168.255.77, 7w0d
B        217.151.242.160/30 [20/0] via 192.168.255.77, 7w0d
Jaderson Pessoa
First traceroute
Second traceroute
you didn`t take other route for this destination, it just is hidden from your screen. But it is the same first two way out.
Jaderson Pessoa
*** Rate All Helpful Responses ***
