Routing Issue Static Route / Route Map
vinay0202
I need help on routing Issue,
ok i have 2 Router in Network lets Say R1 and R2, R1 connected to cloud with 10mb line VPLS,and R2 is 2Mb line IPVPN, I used Static routes, with EIGRP routing protocol. i want to balence the load equally by using Route map, because now load is diverting to R1 because its 10mb line,can any one tell me how to do it, coz im new for this
in order to use route maps in your scenario, you would have to separate your address space in two and then create the maps accordingly. Can you specify your internal IP address space(s)?
GP
