Routing issue with Cisco 1721
I have connected two Cisco 1721 via a T1 line and WIC1 cards. One router is connected to our main 192.168.8.XX subnet. Other router is connected at a remote location to the 192.168.6.XX subnet. Routers can pass network traffic and browse the network.
I need to run UPS Worldship software from the 192.168.6.XX subnet to connect to a proxy server on the 192.168.8.XX subnet. Unfortunately UPS software only works if it connects from a 192.168.8.XX.
I've attached the config files from the two 1721 routers and want to find out how I can modify the routing on the 192.168.6.XX router so I can pass the UPS traffic to the 192.168.8.XX subnet. I tried changing the fastethernet0 port on the 192.168.6.XX router to a 192.168.8.XX ip address and use the same subnet on a computer but I could not reach the 192.168.8.XX subnet with that setup.
Any ideas would be appreciated.
I attached the config files from both routers.
s.vyas
Can you remove access-lit 7 from 192.168.8.0 router...
Also can u post sh ip route from, both he routers and trace to the destination from both the routers.
