Routing issues between two Interfaces
csco11014562
boot-start-marker
boot-end-marker
memory-size iomem 25
clock timezone gmt +2
no aaa new-model
ip subnet-zero
ip flow-cache timeout active 1
ip cef
username admin privilege 15 secret xxxxxxxxxxxxxxxxxxxxxxxxxxxx
interface Loopback0
interface Ethernet0/0
descritption Link to Sat
bandwidth 512
ip address 86.x.x.62 255.255.255.252
ip nat outside
ip flow ingress
load-interval 30
half-duplex
priority-group 1
interface FastEthernet0/0
description Local LAN
bandwidth 512
ip address 192.168.16.1 255.255.255.0
ip nat inside
speed auto
interface Ethernet1/0
description Link to iConnect
ip address dhcp client-id Ethernet1/0
ip nat outside
ip flow ingress
load-interval 30
shutdown
half-duplex
ip nat inside source route-map NAT_ICON interface Ethernet1/0 overload
ip nat inside source route-map NAT_SAT interface Ethernet0/0 overload
ip nat inside source static tcp 192.168.16.10 1723 interface Ethernet0/0 1723
ip nat inside source static tcp 192.168.16.10 443 interface Ethernet0/0 443
ip nat inside source static tcp 192.168.16.10 25 interface Ethernet0/0 25
ip nat inside source static tcp 192.168.16.10 80 interface Ethernet0/0 80
ip nat inside source static tcp 192.168.16.10 21 interface Ethernet0/0 21
ip nat inside source static tcp 192.168.16.10 110 interface Ethernet0/0 110
ip nat inside source static tcp 192.168.16.10 110 41.222.18.208 110 route-map NAT_ICON extendable
ip nat inside source static tcp 192.168.16.10 25 41.222.18.208 25 route-map NAT_ICON extendable
ip nat inside source static tcp 192.168.16.10 1723 41.222.18.208 1723 route-map NAT_ICON extendable
ip classless
ip route 0.0.0.0 0.0.0.0 86.62.13.61
ip route 193.220.223.241 255.255.255.255 86.62.13.61 permanent
ip route 196.12.15.191 255.255.255.255 Ethernet1/0 41.222.18.254
no ip http server
ip flow-export version 5
ip flow-export destination 192.168.16.10 9996
priority-list 1 protocol ip low tcp smtp
priority-list 1 default high
route-map NAT_ICON permit 10
match interface Ethernet 1/0
route-map NAT_SAT permit 10
match interface Ethernet 0/0
line con 0
login local
line aux 0
line vty 0 4
local local
end
Looking at the configuration above what should I do to allow all traffic to go through e0/0. Note that e1/0 interface is deliberate shutdown cause the moment it is up internet traffic gets routed through it.
What I am missing out mates?
Thanks in advance,
thomas.anthony
you may need to chage your route map Sequence
Thanks for your response. How do you mean exactly? Do you mean route-map NAT_SAT should come first and then NAT_ICON
Please elaborate if I am missing your point.
Thanks in advance,
paul.matthews
Level 5
Level 5
I note that address is DHCP - does the DHCP server allocate a default route as well? a sh ip route with the interface up would be interesting to see.
Ideally you could try manually setting the address, but I accept that may not be possible.
You could also try:
no ip dhcp client request static-route
no ip dhcp client request router
to see if you can make the request reject those options, but I have never tried that...
Another option might be to use Policy Based Routing to simply force all traffic that way, but beware as PBR does not andle re-routing very well!
Please rate all useful posts.
Pavel Bykov
Level 5
Level 5
What does "show ip route" say when both interfaces are up?
