Routing not working correctly between 3885 and 3662
asmith
Ok, I have a new 3885, that we use for our wan, have a pre-exisiting 3662, which also talks with an ACC router, that we are doing away with. problem is, the 3885 WILL NOT get routinf table from ACC, it will get 3662's but not ACC's. But the 3662 DOES get tables from ACC????
here is setup from 3662:
router eigrp 100
redistribute static
redistribute rip
network 10.0.0.0
default-metric 1000 100 255 1 1500
no auto-summary
no eigrp log-neighbor-changes
router rip
redistribute eigrp 100
network 172.16.0.0
default-metric 1
and from 3885:
router eigrp 100
redistribute static
redistribute rip
network 10.0.0.0
no auto-summary
router rip
network 172.16.0.0
default-metric 1
HELP.....
asmith
Recevied this in an email, make any sense ?
change the Ip addresses on the WAN to a 10.1.0.x, that should put those in a different network range so they are not the same as the 3662 WAN. It has to do with they way EIGRP works with multiple routers on the same network gettin updates to the routing table...
thanks,
AL
