Routing on a NM-16ESW module
HYE WILSON
I have a 3745 router that connects to remote branches via point to point T1s. I want to replace P2P with 10/100 Ethernet. 2 FE ports on board are being used. I want to add a NM-16ESW module to provide additional Ethernet connections.
My question is "can I configure each port on the NM-16ESW module as a routed port so that I can connect each remote site to the FE port on the switch module?" The way I read, I should be able to do this using SVI. Can anyone confirm this?
I greatly appreciate your response.
Thanks in advance.
H. Wilson.
5 Replies 5
pkhatri
Level 11
Level 11
Howdy,
The way I would do this is to configure a separate VLAN for each port (using 'switchport access vlan') and then configure a separate SVI (interface vlanx) for each VLAN e.g.
interface fast0/0/0
switchport access vlan 100
interface fast0/0/1
switchport access vlan 101
interface fast0/0/2
switchport access vlan 102
interface fast0/0/3
switchport access vlan 103
interface vlan100
ip address....
interface vlan101
ip address....
interface vlan102
ip address....
interface vlan103
ip address....
Hope that helps - pls rate posts that help.
Paresh
Thanks Paresh. One additional question. I am assuming that when I do this I need to add vlan subnets in my routing protocol. For example, let's say the vlan100 is in 172.100.x.x network and I use rip routing protocol. So I should have
router rip
network 172.100.x.x
Is it correct?
Thanks for your help in advance.
HYW.
Yes, you are very correct.
G'day,
That is absolutlely correct. Treat the VLAN interfaces as standard layer 3 interfaces ..therefore,just include their subnets within the network commands of all routing protocols that you wish to run.
Hope that helps - pls rate the post if it does.
Paresh
H.Wilson,
With newer IOS;es, you necessarily dont need to create vlans and then assign vlans to the ports and assign ip addresses to the vlan interfaces to get layer 3 routing on each port. You can do a "no switchport" directly under the fast E ports of the module and this command configures the switch port as a Layer 3 port. Take a look at this FAQ
http://www.cisco.com/en/US/products/hw/modules/ps2643/products_qanda_item09186a00802c9e7a.shtml
You can also enable routing protocols on these ports, just like you do with other interfaces.
PS: Please remember to rate helpful replies!
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
