I asked Cisco's AI, and it said that all LAN ports, except the WAN ports, are only Layer 2. To configure Layer 3, do I need to set up an SVI on the router?
11-22-2025 03:10 AM
Hi team,
Besides the WAN ports on the IR8340/K9 device, the LAN ports also support routing (can operate at Layer 3).
Thanks team
Solved! Go to Solution.
11-22-2025 04:05 AM
- @HatDauNho Yes ,
M.
11-22-2025 04:30 AM
- @HatDauNho There is no link to confirm this , any router will accept routing on it's lan ports but it must be configured
as a layer 3 port first , otherwise you can not make a path to the outside world (WAN port)
M.
11-22-2025 05:29 AM
- @HatDauNho Yes, that's the best thing to do, then put the particular port in the corresponding vlan,
M.
11-22-2025 08:16 AM
according to https://www.cisco.com/c/en/us/td/docs/routers/ir8340/software/configuration/1717x/b_ir8340_cg_17-17-x/m-iox-application-hosting-17-8.html?bookSearch=true#Cisco_Task.dita_7e31bcaf-3f52-404c-9a56-b9fca1a841ed
the IR8340 supports
Step 4 |
interface type number Example:
Configures an interface and enters interface configuration mode |
Step 5 |
no switchport Example:
Places the interface in Layer 3 mode, and makes it operate more like a router interface rather than a switch port. |
Step 6 |
ip address ip-address mask Example:
the reason in this procedure is to prepare for application hosting,
but it does show the ability to attach an ip-address to a port directly
11-22-2025 04:05 AM
- @HatDauNho Yes ,
M.
11-22-2025 04:17 AM
Hi Mark Elsen,
Can you share the link ?
11-22-2025 04:30 AM
M.
11-22-2025 05:19 AM
Hi Elsen,
11-22-2025 05:29 AM
M.
11-22-2025 05:46 AM
Hi Elsen,
But what I want to ask is whether it’s possible to assign an IP directly on these ports, or can it only be configured through an SVI?
11-22-2025 08:16 AM
the IR8340 supports
Step 4 |
Step 5 |
Step 6 |
