Routing over VPC
Amirmahdi.M
Hi everyone
We have 2 TenG links with a datacenter and they were configured as L3 interfaces.
we decided to port-channel them so we can have on Logical Interface.
Our side is a cisco 7600 and the other side is 2 nexus 3064 switches with vPC configured on them.
the second nexus switch is for redundancy.
This is our config:
interface Port-channel10
description DC.PO
switchport
switchport access vlan 900
switchport mode access
load-interval 30
mls qos vlan-based
spanning-tree portfast
spanning-tree bpdufilter enable
end
interface TenGigabitEthernet4/7
description DC1
switchport
load-interval 30
mls qos vlan-based
no cdp enable
channel-group 10 mode active
end
interface TenGigabitEthernet4/8
description DC2
switchport
load-interval 30
mls qos vlan-based
no cdp enable
end
interface Vlan900
description DC.L3
ip address 172.16.1.1 255.255.255.248
no ip unreachables
no ip proxy-arp
ip verify unicast source reachable-via any
load-interval 30
end
router bgp 10
neighbor 172.16.1.2 remote-as 200
neighbor 172.16.1.3 remote-as 200
BGP peer is configured on both nexus switched so thay can be redundant.
the problem is that some src-dst-ips become unreachble and we have to shut on of the interfaces.
I know there is layer 2 connectivy between the switches because even though one interface is down, both bgp nieghbors are still up.
looks like the frame is passing the primary switch to reach the other one and by the way the datacenter used Interface Vlan.
unfortunately i dont have the configuration the datacenter used.
I'd be glad if anyone can help me figure out why some of the traffic is being dropped and offer a solution.
Amir
Sure yes
According to topology you share and info there is something wrong,
Collect all config and checks and share if you need help with
MHM
12 Replies 12
Amirmahdi.M
Also they tried running HSRP and the ip addresses were pingable but the tcp connection couldnt be established so we rolled it back.
M02@rt37
hello @Amirmahdi.M
Interface Po 10 is not in a vPC configuration ?
Best regards
Hi M02@rt37
We configured a normal port-channel on our side.
The datacenter used vPC because they had 2 different switched.
Can you share topolgy
MHM
This is the topology.
CSR4 is our C7600. it's Gi1 and Gi2 are port-channeled.
I will start troubleshooting
Now form two nsk to dc is ok since it l3
From two nsk to csr issue,
the port channel must config as vpc
Interface port channel x
Vpc x
The vlan 900 since we config it as vpc po to two nsk must be vpc vlan i. E. It must allow in peer link trunk
Do above then we check the issues of next hop.
MHM
As far as i know csr(c7600) side doesnt support vpc. (i dont think we need it on our side)
I think the peer link is trunk and passing the vlan because despite one of the interfaces is shutdown right now, i have layer 2 connectivty with it and its pingable.
I edited the post and inserted the complete config on the interfaces.
The csr config as port channel with ldap active or mode ON,
This PO have two legs one for each nexus (these nexus must run vpc).
As far as i know the nexus devices are running vpc.
is it possible that there is a misconfiguration on the nexus devices which causes the traffic going to one of the switches be dropped?
and if so what could it be?
Sure yes
MHM
I will recheck the configuration with the datacenter.
This is my idea of what is happening:
                        ------------- NX1(MAC2)
C7600(MAC1) |                                 |
                        -------------NX2(MAC3)
Maybe in the forwarding proccess im sending a frame with source MAC1 and destionation MAC3 to NX1 and viceversa (port-channel balancing) and for some reason the traffic is being dropped.
Thanks for your help
Amir
Hi @MHM Cisco World
After a few hours of troubleshooting, looks like the problem was with the routing table of on of the switches .
Amir
