Routing port 80 and 443 out a secondary interface/route
Dan Loring
So I have a remote office connected via an MPLS.  I am adding a broadband connection to this site as well and want all port 80 and 443 traffic routed out the Broabband connection.  The mpls is serial0/0/0(55.55.55.55/30) and the broadband is connected to fastethernet0/2(44.44.44.44/30)
What routes would I need to configure this?
You can't do that with pure ip-routing. For that you have to use policy-basrd-routing:
First you have to specify the traffic that should be routed in a specific way:
ip access-list extended WEB-TRAFFIC
  permit tcp any any eq 80
  permit tcp any any eq 443
Then specify the routing in a route-map:
route-map WEB-POLICY permit 10
 match ip address WEB-TRAFFIC
 set ip next-hop 44.44.44.44
Last, apply the route-map to the interface where the WEB-clients are located:
int vlan X
  description LAN-interface
   ip policy route-map WEB-POLICY
Here are some links to more information on PBR:
http://blog.alwaysthenetwork.com/tutorials/policy-based-routing-tutorial/
http://www.petri.co.il/how-to-use-cisco-ios-policy-based-routing-features.htm
