routing problem on cisco 887
Stas Balabanov
Hello everyone!
Please help
i have pings from router to outside (internet) and from router to inside (lan) but i have no ping from inside to outside ,
it seem like nat table is wrong or router just not doing routing...
please have a look at my configuration, may be you'll see something suspicious.
version 15.1
no service pad
hostname Riwip-R
boot-start-marker
boot-end-marker
enable secret 5 $1$ijuH$FLQZC0k.e.Zq/ya41uYFa0
enable password *********
aaa new-model
aaa session-id common
memory-size iomem 10
ip source-route
ip cef
ip domain name
no ipv6 cef
license udi pid CISCO887VA-K9 sn FTX1715828L
username ***** privilege 15 secret 4 8R9Jpx2OkfxKJM2qBI.
d617QvuuNwdr@#EA7Yb.ebRE
controller VDSL 0
ip ssh version 2
interface Ethernet0
no ip address
pppoe-client dial-pool-number 1
interface ATM0
  no ip address
shutdown
  no atm ilmi-keepalive
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
shutdown
interface FastEthernet2
no ip address
shutdown
interface FastEthernet3
  no ip address
interface Vlan1
ip address 10.0.0.130 255.0.0.0
ip nat inside
no ip virtual-reassembly in
interface Dialer0
mtu 1492
ip address negotiated
ip nat outside
  encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
dialer-group 1
ppp pap sent-username *****@****password 0 ************
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list NAT-ACL interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
ip access-list extended NAT-ACL
permit ip 10.0.0.0 0.255.255.255 any
dialer-list 1 protocol ip permit
line con 0
no modem enable
line aux 0
line vty 0 4
privilege level 15
password **********
transport input ssh
end
cadet alain
Your config looks correct. Can you verify the default-gateway on the hosts is the vlan 1 IP address and that they are in the correct subnet.
Alain
cadet alain
Alain
Thank you
That was the problem.
johnlloyd_13
Level 9
Level 9
hi,
could you try with a standard ACL for your NAT?
no ip nat inside source list NAT-ACL interface Dialer0 overload
access-list 1 permit 10.0.0.0 0.255.255.255
ip nat inside soource list 1 interface dialer0 overload
