04-02-2019 03:38 PM - edited 04-02-2019 03:40 PM
Hi guys
Hopefully someone will tell me the secret of this problem.
I just cannot reach out of my DHCP router as you'll understand on the pic or I have attached Packet Tracer file below as well...
Solved! Go to Solution.
04-02-2019 04:19 PM
Hi @Osman D. ,
I have attached the file working.
About the changes made:
-I have corrected the indicated gateway in the DHCP pool to match the address entered in the subinterfaces.
-When using static routes, it becomes unnecessary to use the RIP protocol, so I have also deleted it.
-I've corrected the internet address to do tests.
-I have modified all the static routes, since they had errors.
You can check all the changes in the attached file.
04-02-2019 04:19 PM
Hi @Osman D. ,
04-02-2019 05:30 PM
You did very good Luis but there is no Default Gateway and no vlan numbers on switches...
What I did is a school thing, on the paper this is what they want....
All stupid configuration together...
Thanks for your effort Luis :o)
Osman
