Routing problem
becostergaard
I am having a problem configuring a Cisco 2600 router. The router has 2 ethernet ports and one ADSL WAN port. I have configured the router as a VPN server and when I connect to it over VPN I can ping one of the ethernet ports but not the other. Also, on the ethernet port that I can ping (FE0/0), I can ping the primary IP address but not its secondary IP address.
Below is my router configuration. If anyone could help me with this I would appreciate it,
thanks,
Rebecca
Router#show config
Using 2855 out of 29688 bytes
version 12.3
hostname Router
boot-start-marker
boot-end-marker
no logging console
aaa new-model
aaa authentication login ezvpnxauth local
aaa authorization network ezvpnnetwork local
aaa session-id common
ip subnet-zero
ip cef
ip dhcp excluded-address 192.168.0.0 192.168.0.199
ip dhcp excluded-address 10.1.2.0 10.1.2.1
ip dhcp pool e0Pool
network 10.1.2.0 255.255.255.0
dns-server 203.0.178.191
default-router 10.1.2.1
lease 7
ip dhcp pool e1Pool
network 192.168.0.0 255.255.255.0
default-router 192.168.0.5
lease 7
ip audit notify log
ip audit po max-events 100
vpdn enable
vpdn ip udp ignore checksum
vpdn-group pppoe
request-dialin
protocol pppoe
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp policy 3
encr 3des
group 2
crypto isakmp xauth timeout 60
crypto isakmp client configuration group EZVPNgroup
key beccaspw
dns 203.21.20.20 203.10.1.9
pool ezvpnpool
acl 100
crypto ipsec transform-set my-transform esp-3des esp-sha-hmac
crypto dynamic-map ezvpn-dymap 1
set transform-set my-transform
reverse-route
crypto map MYCMAP client authentication list ezvpnxauth
crypto map MYCMAP isakmp authorization list ezvpnnetwork
crypto map MYCMAP client configuration address respond
crypto map MYCMAP 65535 ipsec-isakmp dynamic ezvpn-dymap
interface ATM0/0
no ip address
no atm ilmi-keepalive
pvc 8/35
pppoe-client dial-pool-number 1
dsl operating-mode auto
interface FastEthernet0/0
ip address 172.17.2.1 255.255.0.0 secondary
ip address 10.1.2.1 255.255.255.0
ip nat inside
ip tcp adjust-mss 1452
duplex auto
speed auto
interface FastEthernet0/1
ip address 192.168.0.5 255.255.255.0
ip nat inside
duplex auto
speed auto
interface Dialer1
mtu 1492
ip address dhcp
ip nat outside
ip address slarp retry 10
encapsulation ppp
dialer pool 1
crypto map MYCMAP
ip local pool ezvpnpool 10.1.2.240 10.1.2.250
ip nat inside source list 1 interface Dialer1 overload
ip http server
no ip http secure-server
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 10.1.2.0 255.255.255.0 FastEthernet0/0
access-list 1 permit 10.1.2.0 0.0.0.255
access-list 1 permit 192.168.0.0 0.0.0.255
access-list 100 permit ip 10.1.2.0 0.0.0.255 any
dial-peer cor custom
line con 0
line au
Richard Burts
Rebecca
I believe that part of the explanation of your situation is that when you connect over VPN your PC is assigned an address in the ezvpnpool of 10.1.2.240 to 10.1.2.250. This put them in the same subnet as the primary address of FastEthernet0/0. So when the PC attempts to ping the FastEthernet0/0 interface it is in the locally connected subnet and the PC does it easily. To ping FastEthernet0/1 or to ping the seconday address of FastEthernet0/0 is attempting to access a "remote" address and to do that the PC must use its default gateway. And I think that the default gateway on the PCs is not pointing to your router.
I also notice that you have a static route configured for:
I do not understand why you have this static route. The connected subnet should be in the routing table anyway.
Check the gateway issue and let us know what you find.
Rick
Rick
