Routing Problem
xhackuss1
I have a routing problem that I need some help for.
I am connected to a network 10.21.17.0 with a default-gateway of .1
I have another vlan that terminates on my gateway of 10.21.17.1. This vlan is 10.100.1.64/27 . The vlan has an address of 10.100.1.65/27.On my gateway,I can ping 10.100.1.65,66,67,68,69 which are on thesame network 10.100.1.64/27.from my PC,I can ping the vlan address of 10.100.1.65 but cannot ping the others(i.e 10.100.1.66,67,68 and 69).
I have a route on my gateway as
ip route 10.100.1.64 255.255.255.224 10.100.1.69
Is there something I am missing out?
Help needed ASAP
Try configuring 'no ip redirect' on the router interface configured with an IP address of 10.21.17.1.
If you are still having problems let us know how's your network setup.
Pls. rate all helpful posts.
Sundar
thanx but the 'no ip redirect' could not work as I am using a 3750 switch as the router.
Below is my configuration.
Rtr#
interface GigabitEthernet1/0/1
description Trunk to GRTPX
switchport trunk allowed vlan 101,603
switchport mode trunk
no ip address
no mdix auto
storm-control broadcast level 5.00
storm-control multicast level 5.00
interface GigabitEthernet1/0/2
switchport access vlan 4
switchport mode access
no ip address
no mdix auto
interface Vlan4
ip address 10.100.1.65 255.255.255.224
interface Vlan603
ip address 10.21.17.1 255.255.255.0
router ospf 222
network 10.21.0.0 0.0.255.255 area 0
On this router I can ping devices on the 10.100.1.64/27 subnet but I cannot ping thesame devices from the 10.21.17.0/24 subnet
Any fix?
Are you using 10.100.1.65 as the gateway for hosts on 10.100.1.64/27 subnet? If you don't, can you set that as the gateway for one host and try?
Sundar
in addition to Sundar's posts, what do you need the static route for ?
And what is 10.100.1.69 ?
You would not need the static route at all, since the network is directly connected, so try and take it out of the configuration...
GNT
