Routing PT server to router
samrodriver
Hi everyone.
So I have an assignment where I have to control several IoT items from a smartphone through a radius server service. However, even before trying to configure it properly, I am having problems to create a connection between the server and the wireless router, the ping always times out. I think I have my configuration properly assembled, so I am asking for your help to get something I have missed out.
Thank you!
the first thing I noticed is that the wireless router has a LAN IP address of 192.168.0.1/30, that leaves only one other address in the LAN (192.168.0.2). The static IP address you assigned to the Smartphone is not in the same subnet, so you need to change the mask to something bigger, or change the IP addressing altogether.
Keep in mind that you will never be able to get an ICMP response from a wireless router in Packet Tracer, these devices do not respond to pings.
