Routing between SVI and routed port on router
fazooladmi
How can I achieve reachability from vlan terminated on the L3 switch to routed port on the router, FW?
F.E
int vlan 10,50 are the SVI's on L3 switch
vlan 10 - 10.0.10.254 /24
vlan 50 - 10.0.50.254 /24
vlan 50 is the native vlan on trunk link towards (router, FW)
Routed port is configured on the physical interface with 10.0.50.1/24
Problem is that I can reach routed port sourcing from both SVI's but no from the device being inside vlan 10
Taking tcpdump on the routed interface i can see only icmp requests but no replies. Switch does have default gateway set to 10.0.50.1
I've enabled ospf on FW and switch but with no luck.
Thanks @Zac67 for the hint, maybe I wasn't clear what I try to achieve.
I want to have few vlans terminated on the L3 switch, some of them on the FW to have visibility in them. Problem is that I would like to use physical interface on the FW to be their DG to reach outside world or route to the vlans terminated on the FW.
It looks like router on the stick but with usage of physical interface by putting ip address on it.
So vlans 5,10,15.20 terminating on the L3 switch so they have SVI's created on it. Vlans 30,40,50 just existing on the switch and going to the router thru trunk and they have their own subinterfaces created.
I am looking for a way to use another vlan just for connectivity between SVI and router physical interface.
What I did until now is let's say create SVI for vlan 100 put ip on it - set vlan 100 as a native vlan on the trunk to reach the router untagged.
But it doesn't work unfortunately... Jbbattery portugal
First of all sorry for all the mistakes I made and making in this question - this is first time posting on stack. Thank you all who is trying to help solve this problem. Please find the topology and configs below:
Switch config
Current configuration : 3350 bytes
! Last configuration change at 06:18:12 UTC Thu Aug 26 2021
version 15.2
service compress-config
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
spanning-tree mode rapid-pvst
vlan internal allocation policy ascending
interface GigabitEthernet0/0
 media-type rj45
 negotiation auto
interface GigabitEthernet0/1
 switchport access vlan 20
 switchport mode access
 media-type rj45
 negotiation auto
interface GigabitEthernet0/2
 media-type rj45
 negotiation auto
interface GigabitEthernet0/3
 switchport trunk native vlan 40
 switchport mode trunk
 media-type rj45
 negotiation auto
interface GigabitEthernet1/0
 switchport access vlan 30
 media-type rj45
 negotiation auto
interface GigabitEthernet1/1
 media-type rj45
 negotiation auto
interface GigabitEthernet1/2
 media-type rj45
 negotiation auto
interface GigabitEthernet1/3
 media-type rj45
 negotiation auto
interface Vlan20
 ip address 10.0.20.254 255.255.255.0
interface Vlan40
 ip address 10.0.40.254 255.255.255.0
router ospf 1
 network 0.0.0.0 255.255.255.255 area 0
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
banner exec ^C
* IOSv is strictly limited to use for evaluation, demonstration and IOS  *
* education. IOSv is provided as-is and is not supported by Cisco's      *
* Technical Advisory Center. Any use or disclosure, in whole or in part, *
* of the IOSv Software or Documentation to any third party for any       *
* purposes is expressly prohibited except as otherwise authorized by     *
* Cisco in writing.                                                      *
**************************************************************************^C
banner incoming ^C
banner login ^C
line con 0
 logging synchronous
line aux 0
line vty 0 4
 login
end
Router config
Router#sh run
Building configuration...
Current configuration : 3144 bytes
! Last configuration change at 06:18:16 UTC Thu Aug 26 2021
version 15.6
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ethernet lmi ce
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip cef
no ipv6 cef
redundancy
interface Loopback0
 ip address 3.3.3.3 255.255.255.255
 ip address 10.0.40.1 255.255.255.0
 duplex auto
 speed auto
 media-type rj45
interface GigabitEthernet0/0.30
 encapsulation dot1Q 30
 ip address 10.0.30.1 255.255.255.0
 no ip address
 shutdown
 duplex auto
 speed auto
 media-type rj45
 no ip address
 shutdown
 duplex auto
 speed auto
 media-type rj45
 no ip address
 shutdown
 duplex auto
 speed auto
 media-type rj45
router ospf 1
no ip http server
control-plane
banner exec ^C
banner incoming ^C
banner login ^C
line con 0
line aux 0
line vty 0 4
 login
 transport input none
no scheduler allocate
end
Sourcing from VPC10 I can ping
VPCS> ip 10.0.30.100 /24 10.0.30.1
Checking for duplicate address...
PC1 : 10.0.30.100 255.255.255.0 gateway 10.0.30.1
VPCS> ping 10.0.30.1
84 bytes from 10.0.30.1 icmp_seq=1 ttl=255 time=16.253 ms
VPCS> ping 10.0.40.1
84 bytes from 10.0.40.1 icmp_seq=1 ttl=255 time=8.569 ms
VPCS> ping 10.0.40.254
84 bytes from 10.0.40.254 icmp_seq=1 ttl=254 time=12.776 ms
VPCS> ping 10.0.20.254
84 bytes from 10.0.20.254 icmp_seq=1 ttl=254 time=15.602 ms
VPCS> ping 10.0.20.100
10.0.20.100 icmp_seq=1 timeout
VPCS> ping 3.3.3.3
84 bytes from 3.3.3.3 icmp_seq=1 ttl=255 time=11.675 ms
Only device which is not pingable is other VPCS 10.0.20.100
**But from VPC which is terminated on the switch only SVI's on the switch**
VPCS> ip 10.0.20.100 /24 10.0.20.254
PC1 : 10.0.20.100 255.255.255.0 gateway 10.0.20.254
84 bytes from 10.0.20.254 icmp_seq=1 ttl=255 time=25.344 ms
10.0.30.1 icmp_seq=1 timeout
84 bytes from 10.0.40.254 icmp_seq=1 ttl=255 time=7.528 ms
pman
your post is somewhat confusing, as there are no SVIs for Vlan 10 and 50 configured on the switch, just 20 and 40...
Hello
You have a native vlan mismatch between switch and rtr, The rtrs physical interface defaults to vlan1, change the switch trunk to be native vlan1 or perform the following, test again.
RTR
no ip address 10.0.40.1 255.255.255.0
interface GigabitEthernet0/0.40
encapsulation dot1Q 40 native
Kind Regards
Paul
