routing question
kp-tkr2014
I have the below topology . When the link from the router  to ISP is disconnected , I am not able to access the   router  using the ip 1.1.1.1 . from ASA I have default route
Any suggestion
what routes does the router have ? Post the full configs of the ASA and the router...
Hello
From were are you trying to access the rtr on 1.1.1.1?
Kind Regards
Paul
balaji.bandi
We need more information, what source you try to ping 1.1.1.1
1. From external you will not able to since ISP router connection down.
2. From ASA you should be able to ping since its point to point link (is this tested) ?
So port Router full config.
BB
